This is a FAQ regarding HID beams. It is not a How-To, so I welcome everyone to throw in their comments or their experiences. Most of it will just pictorial comments since theres not much to talk about.
Kit:ebay generic kit, XENTEX brand.
Dual Bi-xenon 35watt 5000K (Bi-xenon is an actual magnet that moves the bulb and refocuses the beam.
Monsterparts Dual Headlights (originally dual h4)
General CommentsSince I run a Bixenon kit, the bulb itself is actually much longer than what the stock ducati mono headlight housing can fit. This means you will either need to cut your headlamp (just a 1 inch diameter hole in the back will suffice) or get some other sort of bixenon, or just get a bixenon altogether. Bixenon kits also have a controller and often the wires in the kits are designed for cars, not motorcycles, so the dimensions of it are a pregnant dog to work with. I will eventually get to sorting out the wires, but as of now. I am too lazy, and my spare time gets spent watching football, doing school work, looking for boobies while doing school work (nerdy chicks are hot) or writing stuff for the DMF. So here you are. HIDs in a jiffy.
(note, just uploaded, may not work yet)
Stock H4 MonoheadlightThese first few pictures are all shot with the following settings
F2.8
Ex 1/20
ISO-200
No editing
My reason to make it so dark is to make sure you see the central beam and not glare or any of the sort.
Here is the stock monoheadlight H4 dead on
Sideview
The actual beam
HID kit DUAL BIXENON 35WATT TEST PHOTOSSame settings as above Side view, there is no center view because it was so damn bright, you really didnt see a difference from side or front becasue your cornea would just burst into flames (and zombies would walk the earth and kill you until you die)
The actual beam. Note that when you compare it to the H4, there isnt as much light. I don't know why this is so. But later on, you'll see a pic of what you will actually see.
This is the LOW BEAM HID
NOTE DIFFERENT SETTINGS FOR BOTH HIGH AND LO BEAM!!!!!!F2.8 (no change)
Ex 1/13 (Previously Ex 1/20)
ISO-100 (Previously ISO200)
This is the HIGH BEAM HID
What you actually seeThis is when your tucked in
When your sitting on the bike
And when you are an innocent bystander
The EquipmentThis is the Kit itself
The duals
The Mess of Wires
This is one thing I do not like about the kit, you dont really notice it, but the 2 bulbs are actually different temperatures. I have a 1 year warranty on them, and the seller says i can return them if I dont like it.
This was shot at 1/1250 F7.2 at ISO80
