The biggest problem I had was I couldn't find a 25/64ths drill bit anywhere. I had to "make it work" with 3/8ths.
The red arrows on the first pic show the internal web they are referring to. They just want you to miss cross structure.
About where I want it.
Checking clearance.
Mark it dude.
Looks about right.
Measuring for the other side.
Punch it.
Drill it.
There is a big hole in my swingarm!
Push in the insert.
Crushing it.
Don't forget the locktite.
Put on the spool.
And there you have it.
I had a little trouble with the right side spinning when I put on the spool. Combo of having to "route it out" with the 3/8ths and not crushing it enough I guess. I got the spool back off, no thanks to the locktite.
I crushed the ever loving shite out of the insert again, and all was well after that.
Time for...
