March 28, 2024, 03:00:59 PM
changing MPH to KPH
Topic: changing MPH to KPH (Read 10628 times)
changing MPH to KPH
January 27, 2009, 11:26:40 AM »
Does anyone know how to change the 696 to indicate Kilometers per hour instead of MPH and still be in english?
S2R 800 '07
Re: changing MPH to KPH
January 27, 2009, 04:46:09 PM »
Australian? If available?
Iconoclast
January 28, 2009, 05:58:42 AM »
This will work.
Mind you, my setup is for converting kph to mph so I'm not sure where you will find a reverse setup.
Last Edit: January 28, 2009, 06:16:20 AM by Iconoclast
Big Troubled Bear
The wrong side of normal
98 m900 sold, Red 696
January 28, 2009, 06:05:56 AM »
Have you tried downloading the owners manual from Ducati.com, there they explain how to
andym
January 28, 2009, 11:38:38 AM »
I did not think there was any language setting.
As far as I know it only changes distance, speed and temperature.
UK = miles, mph, Celsius.
US = miles, mph, Fahrenheit.
EU = KM, kph, Celsius.
I'm not sure what the JAP, CAN or FRA displays are, just try them and see if it what you want.
This is how you change it.
1) Hold the mode switch up while you turn the key to on. Hold it up until the display reads "00000 PRO". Release switch.
2) Press the switch up until the display will read "UNIT SET"
3) Hold the switch down until display reads "US". Release switch.
4) Press the switch down until you get to the desired setting.
5)Hold the switch down until the display reads "MEM xx" then Release switch.
6) Turn key to off position.
M696 Dark
January 28, 2009, 01:01:14 PM »
Thanks,
For some reason i thought it was country selective not region.
January 28, 2009, 01:43:13 PM »
Quote from: Iconoclast on January 28, 2009, 05:58:42 AM
This will work.
DO YOU SERIOUSLY RIDE LIKE THAT??? hey at least you are using ductape
Iconoclast
January 28, 2009, 02:12:19 PM »
Quote from: Raux on January 28, 2009, 01:43:13 PM
Nah, not really. Too much time on my hands today with the snow blizzard we're having.
Actually, I wondered when a Ducati would be produced with a digital speedo that allowed for changes to/from kph to mph. Didn't know until today that they already existed.
January 29, 2009, 03:05:01 AM »
ok done. thanks all.
Keld
January 29, 2009, 08:18:43 AM »
Quote from: Iconoclast on January 28, 2009, 02:12:19 PM
Thanks for the effort
Gimpy
Not quite a
January 29, 2009, 09:43:31 AM »
This will work.
Thanks for that! made my morning!
2001 M900 Dark
andym
January 29, 2009, 12:56:20 PM »
Quote from: Raux on January 29, 2009, 03:05:01 AM
What did you go with?
Did you find one that did KM, KPH & Fahrenheit?
M696 Dark
January 29, 2009, 01:39:54 PM »
Quote from: andym on January 29, 2009, 12:56:20 PM
i used the EU. i'm used to Celcius so it's not a problem for me.
andym
January 30, 2009, 07:57:17 AM »
Quote from: Raux on January 29, 2009, 01:39:54 PM
[/quot
Cool, I use UK here in Dallas, I'm from England so having miles and Celsius is great for me.
M696 Dark
