April 22, 2024, 11:51:35 PM
Electrical - 96 M900 - Obscene screeching buzz & no juice - FIXED!!!!!
Topic: Electrical - 96 M900 - Obscene screeching buzz & no juice - FIXED!!!!! (Read 6055 times)
dropstharockalot
Sex-Toy Bludgeonin'
The Teabaggin' Dragon
May 03, 2009, 09:40:30 AM »
Multi-part question.
1) What the hell is this thing?
Same part, removed from it's rubber frame mount... the pale brown plastic cover sez: "Type 23 / B 047 / 12V.40A"
Once the cover is removed, the coiled wires, springs, and little contact arm are exposed - but not so clear in this crappy pic:
2) Why is it emitting an awful, high-pitched buzzing sound whenever I flip the key to "on"?
3) Is that awful, high-pitched buzzing sound the reason that none of my lights or indicators function, and my start button is not starting the bike?
Thanks in advance for any assistance.
To show my appreciation, please enjoy this image:
Last Edit: May 07, 2009, 07:02:37 PM by dropstharockalot
'96 M900
Re: Electrical - 96 M900 - Obscene screeching buzz & no juice
May 03, 2009, 09:43:55 AM »
It is the main relay, and yes it is the reason nothing works.
I think there may be some replacement info in the sticky thread at the top of the page.
greenmonster
May 03, 2009, 10:47:25 AM »
When you turn ign on, you see how it works now w/o the hood.
The little copper thingy should connect/not connect.
Simply adjust that and wetsand just a little & clean the mating surfaces and it should work again.
Last Edit: May 03, 2009, 02:59:51 PM by greenmonster
M900 -97
MTS 1100s -07
dropstharockalot
Sex-Toy Bludgeonin'
May 03, 2009, 12:47:56 PM »
Quote from: ducpainter on May 03, 2009, 09:43:55 AM
The "Cheap Replacement Parts" thread?
///stupid on Sundays...
'96 M900
monsta
Perth, Australia.
May 03, 2009, 02:15:28 PM »
mine did that (made the high pitch buzzing) when I had dirty contacts on the battery cables. I'm guessing that resistance in the leads ment that there wasn't enough pull to make the relay work properly?
anyhow, cleaned the battery leads (after checking relay) and all good....
May 03, 2009, 03:25:21 PM »
Quote from: dropstharockalot on May 03, 2009, 12:47:56 PM
That's the thread I meant.
greenmonster
May 04, 2009, 04:53:44 AM »
Quote
Because contact is bad.
Try my little recipe, simple & funtional.
Done it on at least 5 bikes by now.
M900 -97
MTS 1100s -07
dropstharockalot
Sex-Toy Bludgeonin'
May 04, 2009, 05:00:51 AM »
OK, I'm gonna give the sandpaper trick a whirl. Fingers crossed...
'96 M900
greenmonster
May 04, 2009, 05:11:43 AM »
Main thing is to adjust so it clearly connects-disconnects when you turn on ignition.
M900 -97
MTS 1100s -07
dropstharockalot
Sex-Toy Bludgeonin'
May 05, 2009, 04:32:56 AM »
I'm trying to work the main relay free from the connector, but it doesn't want to come free - am I missing a toggle or connector or latch or something, or is it just wedged in there pretty good?
///doesn't wanna apply leverage and have the thing detonate into a bazillion pieces...
Thx again.
'96 M900
May 05, 2009, 07:35:51 AM »
Put the cover back on the relay, so you can grab it without tweaking things.
Then hold the connector body and wiggle/pull on the relay.
Sounds like the terminals may be corroded, likely part or all of your problem.
greenmonster
May 05, 2009, 03:43:24 PM »
Maybe my English is too limited, I`m talking about connection inside here:
The flat copper thingy w a round spot that makes contact w the spool of copper.
Make sure it connects/disconnects as it should.
M900 -97
MTS 1100s -07
May 05, 2009, 03:49:59 PM »
Quote from: greenmonster on May 05, 2009, 03:43:24 PM
I
think
what Speeddog was saying is the fact that the connector won't come apart is an indication of a corroded connection which may prevent the relay from receiving enough voltage to work properly.
greenmonster
May 05, 2009, 04:17:01 PM »
Think that`s also what speedog means.
But, I have fixed several relys w the little mod I`ve mentioned.
M900 -97
MTS 1100s -07
Reply #14 on:
May 05, 2009, 04:19:51 PM »
Quote from: ducpainter on May 05, 2009, 03:49:59 PM
I
think
Yeah, that's what I meant.
Once the relay's disconnected, you can test it, no need to futz with the innards of it if it's working.
=> Stalla's Pop
