April 19, 2024, 02:43:00 PM
Ducatitech.com: Oil Change How To!
Topic: Ducatitech.com: Oil Change How To! (Read 32094 times)
dcal
May 06, 2008, 03:28:29 PM »
Last Edit: May 07, 2008, 08:09:00 AM by dcal
PizzaMonster
2007 S2R800
Re: Ducatitech.com: Oil Change How To!
May 07, 2008, 06:12:09 PM »
Borrowed a bit of knowledge in the way of an oil filter cross reference posted on the DML by Greg Mo.
This is a cross reference for oil filters which suppose to fit most ducatis, I found it on-line and recently bought the NAPA power sports filter SP7013 and it works
* AMSOil SMF 132/132C this suppose to fit, but amsoil is about to release the real Mc Coy for our Ducs soon
* EMGO 10-26980
* Fram PH6019, PH6074 Fram in general has very low quality filters, not recommended
* K&N KN-153
* NAPA PS7013 this one was about $9, and better then OEM
* WIX 57013
I've personally used the K&N KN-153 on my S2R 800 since my 600 mile check. I like it because it has a hex head pattern on the bottom for easier removal.
The Ducati Monster Forum - Time Well Wasted :-)
Count Desmo
MOΛΩN ΛABÉ
May 09, 2008, 08:38:09 AM »
FYI, the NAPA filters are made by WIX, so they are identical other than part number. Carquest filters are also made by WIX, so they can cross-reference the WIX or NAPA numbers (the Carquest filter number is 84013 and only comes in a chrome finish. This may or may not be to your liking, but will work if you're in a bind.)
Last Edit: May 10, 2008, 06:31:34 AM by Count Desmo
roy-nexus-6
May 09, 2008, 09:54:28 PM »
Excellent post - helped enormously when I did my first oil change! wt:
MuscovyDuc
02' M750I.E. Dark - (pearl white)
May 23, 2008, 03:32:53 PM »
Yep, Did my first oil change today and had no problems because of this video
http://www.madog.us/
http://www.flickr.com/photos/26351347@N03/
http://autos.groups.yahoo.com/group/madog/
mangeldbug
May 23, 2008, 04:14:14 PM »
I remembered how to do everything except how much oil to add at the end. Its not in the Duc manual and not mentioned in LT's book since he covers a wide range of bikes. This video says that you will add 3 quarts, maybe a bit more. He added 3 and then checked the level and then ended up adding quite a bit more.
For me, 3 quarts was way too much. I had to siphon some off.
I have a 2002 M750S and my bike took 2 quarts plus ~600mL of oil
Last Edit: May 23, 2008, 06:06:39 PM by mangeldbug
2002 M750Si.e. "Senna" - Meravigliosa, Mera for short
2017 390 Duke Commuter
2001 XT225 Zombie Assault Vehicle
1987 YSR50 #116 race bike
May 23, 2008, 09:43:00 PM »
Did you change the oil filter? Did you let the bike drip for a few mins? You can try to start the bike up let it cycle a bit, then check to see how much you are at. My bike filed up 3L right at the low. When the bike warms up its right midway.
mmakay
695
May 24, 2008, 09:14:33 AM »
Quote from: Count Desmo on May 09, 2008, 08:38:09 AM
I just purchased a NAPA filter, and it was manufactured by Mann Germany, not Wix. (Unless Wix and Mann are related?) Good quality stuff, either way.
- Mickey
hydra
life is analog...
June 26, 2008, 09:47:51 PM »
he never mentioned that you should try to change the oil when the engine's hot.
and you should just hand tighten the oil filter or that thing will be a b*tch to loosen the next time.
S4 Foggy- tires, battery...
BE WATER
Delmar
Little-Red riding hood???
July 07, 2008, 02:10:07 PM »
I like the instructional vids from ducatitech. I learned how to clean and keep lubbed my chain through one of their videos.
“There are some things nobody needs in this world, and a bright red, hunchback, warp-speed 900 cc café racer is one of them – but I want one anyway, and on some days I actually believe I need one. “ Hunter S. Thompson
BumbleB
August 13, 2009, 07:24:05 PM »
Quote from: Delmar on July 07, 2008, 02:10:07 PM
+1 - great videos, easy to follow, and very informative particularly when paired with content from this forum...
I'm not much for quotes - tell me what you know...
q80lucifer
October 24, 2009, 11:06:15 PM »
Quote from: PizzaMonster on May 07, 2008, 06:12:09 PM
* EMGO 10-26980
* K&N KN-153
* WIX 57013
Nice video very simple and useful. Thanks for sharing that
filter
Bumblebee
October 27, 2009, 03:07:17 PM »
Yeah, nice video!
Does anyone know where to get new crush washers? Are they a standard part you can find at the HW store or do I need to buy ones from my dealer?
01 Monster 750 Dark
(El Matador Tail Chop, Arrow CF exhaust, K&N Filter, CA LED Taillight, Radiantz LED License Plate holder, Blue LED Instrument Cluster, black belt cover, lifted suspension, 14T sprocket, Cycle Cat Billet Side Stand, CRG lanesplitter mirrors, custom Desmo reservoir caps)
=> Stalla's Pop
