March 29, 2024, 01:54:02 AM
S2R 800 changing to a 14 t sprocket.
Topic: S2R 800 changing to a 14 t sprocket. (Read 19588 times)
brimo
酒後吐真言
May 06, 2008, 06:09:45 PM »
Best bang for your buck mod I reckon.
Another popular one on "that other site"
Step one: Bike up on rear paddock stand in gear
2: remove front sprocket cover
3: loosen rear axle retaining bolts
4: loosen chain
5: remove clutch slave cylinder, don't touch the clutch lever after this!!!
6: remove 2 little sprocket bolts
7: turn retaining ring and remove
8: remove sprocket
9: put new one on, blue thread locker on threads, torque bolts to 6 N-m / 4 ft-lb
10: replace other bits, adjust chain, torque value on axle pinch bolts is 33 nm, 24 ft/lb
go for a ride ( after taking it off the paddock stand otherwise you won't get very far)
Last Edit: June 22, 2009, 09:51:26 PM by brimo
From a story by RAT900
SKOM
Upside Down Canuck
Re: S2R 800 changing to a 14 t sprocket.
May 08, 2008, 07:16:28 AM »
I did the same thing on my S2R 800.
Although I didn't have a spanner to slacken up the chain. I tried using a screwdriver and hammer but no go.
There is a tool you can buy from CA cycleworks but I was too cheap to fork out the 20 bucks.
I managed to get the sprocket off because my chain was a bit loose anyway. Getting it on was a super pita. :bang
I'd recommend getting the tool to turn the eccentric as it will make your life easier.
just my 2 cents. The instructions above are right on the money.
"Die gefährlichste Weltanschauung ist die Weltanschauung derer, die die Welt nie angeschaut haben."
— Alexander Von Humboldt
brimo
酒後吐真言
May 08, 2008, 02:23:34 PM »
yep, buy that tool, you'll need it eventually to adjust your chain. There is a couple around, the genuine duc one is a bit pricey though, there's also fleabay, (hammer and screwdriver?
oh dear! damage that eccentric and it'll cost you more than 20 bucks to fix;) )
onaboat
May 08, 2008, 07:07:01 PM »
hi guys, can some one tell me what this tool is called that you guys are talking about, i tried looking for it on ca-cycleworks but no luck. i just received my 14T sprocket and would like to have it in as soon as possible, the bike jerks so much down low :bang. thanks
DucLeone
May 08, 2008, 07:15:26 PM »
i just used a plumber multitool used to tighten sink drains and such
got it at lowe's for a few bucks
DUCATI NON E UNA MOTO, E UN STILE DI VIVERE
KISS FRENCH AND RIDE ITALIAN
S2R 800 Black
Ducatiloo
May 09, 2008, 01:45:21 PM »
It's in this kit
http://www.ca-cycleworks.com/shop/catalog/ducati/img/toolbag_697_200_82b.jpg
750 SS 01
800 S2R 05 Aprilia RST 1000 futura
Ducatiloo
May 09, 2008, 01:47:10 PM »
Here is on minus the kit.
http://cgi.ebay.com/ebaymotors/DUCATI-CHAIN-ADJUSTER-TOOL-SINGLE-SIDE-SWING-ARM-BIKES_W0QQitemZ250245275593QQcmdZViewItem
I wonder why Chris doesn't sell just the Chain Adjuster by itself anymore..
750 SS 01
onaboat
May 09, 2008, 02:25:53 PM »
kool, thanks guys
metaldoc
06 MTS 1000DS, 07 S2R 800
May 13, 2008, 05:08:50 AM »
Quote from: Ducatiloo on May 09, 2008, 01:47:10 PM
Desmo Times does (no I'm not affiliated)
http://www.desmotimes.com/
"A slip of the foot you may soon recover, but a slip of the tongue you may never get over. " - Benjamin Franklin
monster2b
May 13, 2008, 08:56:28 AM »
So does this mod really help? I do a lot of freeway riding and in the carpool lane to keep up you have to do 85-90...allegedly. At those speeds I'm running around 5300 rpms. What would the revs be with the 14t? Will my 800 become a wheely machine (I like both wheels on the ground, thank you very much)?
DucLeone
May 13, 2008, 09:43:06 AM »
Quote from: monster2b on May 13, 2008, 08:56:28 AM
both weehls will stay down, its just alot smoother in low speed areas (Citys)
as far the rpm goes you will elevate them a bit but nothing big
S2R 800 Black
Ducatiloo
May 13, 2008, 10:58:09 AM »
Quote from: metaldoc on May 13, 2008, 05:08:50 AM
can you send me the link to the tool? I cant seem to find it.
750 SS 01
Ducatiloo
May 13, 2008, 10:59:29 AM »
Nevermind I just needed to use that fancy scroll function.
750 SS 01
monster2b
May 13, 2008, 02:04:31 PM »
Thanks for the reply DucLeone.
Oh and Long Live the DMF!
jagstang
Ramming speed...
Reply #14 on:
May 15, 2008, 05:40:07 PM »
Ok, so I have a spanner and a 14t sprocket in the mail, probably coming tomorrow. I REALLY want to install it tomorrow! Problem is that I don't have a rear stand, and I'm not very mechanically skilled with motorcycle maintenance anyway.
1) Is it possible to replace the sprocket with the rear wheel on the ground?
2) What direction do you turn the eccentric to tighten or loosen the chain?
3) What are the torque specs for the pinch bolts on the swing arm?
Thanks!
'09 1100
