April 24, 2024, 02:15:40 PM
How to fix the indicator switch
Topic: How to fix the indicator switch (Read 5445 times)
mmarell
June 26, 2008, 11:20:17 PM »
I bought a second hand Ducati Monster 900 a couple of weeks a go. I knew some minor things needed fixing, among which the indicator switch.
Since I couldn't find an earlier post on a problem like this, I figured I might give others a hand :-)
The indicator switch was only working for the right hand side indicator, for the other side it would only work every now and then, or by moving/pressing the switch in a very funny way.
In my case this was caused by a loose screw inside the switch. To repair it:
- Open the switch (2 screws, cross-heads)
- Remove the metal plate on the lower part (1 screw, smaller cross-head)
- Fasten the screw through the switch lever (1 screw, cross-head), you might want to throw in a bit of silicon spray to smoothen things
- Finally, put everything back together
Often wrong, never unsure...
Bizzarrini
Showing off his
'94 M900
Re: How to fix the indicator switch
June 29, 2008, 05:00:12 AM »
Just as easy as fixin' your doorbell, right?
"As a final touch, God created the Dutch"
