September 03, 2010, 04:39:09 AM *
News: New Avatar Policy: Please Read
  Home   Forum   Help Search Login Register
MotoWheels Page
Pages: [1] 2 3 ... 7   Go Down
Author Topic: Motowheels Project 696  (Read 12615 times)
Sac Monster
« on: June 27, 2008, 11:39:25 AM »
We are planning to do a lot of changes to this monster. We are still learning what parts fit and what parts it needs. Modifications done so far is
CF Front Fender M696 - 1098 Style
SPEEDYMOTO Frame Slider: Mon '01+,MS,SS '03+,748,996,749D,SC, Hypermotard, M696
http://tinyurl.com/5km66y
RHINOMOTO Front Axle Slider: Ducati/Aprilia
http://tinyurl.com/6kzxoo
M696 Bar End Slider/Mirror Kit- We decided to go this route instead of the Oberon bar end turnsignals since we have done that on almost all our project bikes but that would have been another good way to go.
http://tinyurl.com/5zn78v
CRG "Roll-A-Click" Brake/Clutch Lever: Brembo - So far the best modification in my opinion.
http://tinyurl.com/5muoya
We are currently looking at turnsignal options. Below is a comparison of the maddoctor folding turnsignals and stock. The maddoctor is brighter and smaller but not much different looking than stock.
http://tinyurl.com/6myv5r
As for rearsets we are coming up with a kit to make S*R rearsets work on the 696. We should have that together soon, the rearsets below will run about $559 for the S*R and the 696 will require about a $70 kit that will include a new rear brake line.
We relocated the regulator and horn so that we could remove the plastic shroud all together.
We will have more pictures coming as we decide what to do next. We are looking into an oil cooler kit, CF tank side covers, european plastic shroud to replace the one used for the charcoal canister after it is removed, HID kit, wheels, QD slip on exhausts and much more.
« Last Edit: June 27, 2008, 11:44:29 AM by Sac Monster » Logged
SteveH
« Reply #1 on: June 28, 2008, 06:00:00 PM »
Lookin good.  Not really crazy on the front fender though....
Im looking forward to the oil cooler !
Sac Monster
« Reply #2 on: June 28, 2008, 07:36:56 PM »
The front fender was more of a test fit just to make sure any 748-998 or 1098 fender would mount. We are putting either a 696 style one on or a DP Diversion style one on soon.
Spider
Ozmonsters: degenerating nicely since 2008
I may be long, but I fold up nicely
« Reply #3 on: June 28, 2008, 09:15:12 PM »
Diversion fender will look great...
and thank you for doing this...should stop the 'grumpys' from bagging the 696, showing them that it really is a Ducati in spirit...mod the hell out of it!
moto
« Reply #4 on: June 29, 2008, 08:59:37 PM »
I want to put in an 1100cc motor in it with a single sided swingarm...
www.motowheels.com
96 M944
98 900SS FE
01 996R
02 MV Agusta F4 750
05 999R
06 SC1000
07 1098
08 M696
« Reply #5 on: June 29, 2008, 10:36:19 PM »
Heh - wouldn't it be easier to lop the subframe and headlight off a multistroodle or hypermotard and replace them with 696 bits?
Smiley
big
moto
« Reply #6 on: June 29, 2008, 11:30:11 PM »
It only takes a day to swap the motor. Plus I want to build up the motor a bit before it goes in. Swapping parts take a LONG time. We've done this before several times. It would be a lot easier to swap motors.
The MTS and HM has LONG forks--and are very tall bikes. It would not look right for what we want to do.
Maybe we will do a big 4V motor instead...Smiley
And probably not a SSSA. I actually like the M696 swingarm now - it is probably a lot lighter and stiffer than the SSSA set up too.
-M
www.motowheels.com
96 M944
98 900SS FE
01 996R
02 MV Agusta F4 750
05 999R
06 SC1000
07 1098
08 M696
« Reply #7 on: June 30, 2008, 01:41:36 AM »
I was _mostly_ joking, but don't the 1100 SSSA bikes mostly have frames with the swingarm pivot supports on them? Does the SSSA bolt up OK without those outrigger bearings on them?
Quote
Ahhh, I guess that doesn't really matter then...  laughingdp
big
moto
« Reply #8 on: June 30, 2008, 10:24:06 AM »
big
Not sure.
I heard the MTS SSSA was different mounting than the S2R/S4R series SSSA. I remember some of the 2 valve motors were different widths than the 4 valve swingarms- so milling of the cases was required.
I was thinking of all the work for a cosmetic upgrade and thought....maybe not after all...Smiley
Now I'm thinking a big 4V motor in the M696... Smiley
-M
www.motowheels.com
96 M944
98 900SS FE
01 996R
02 MV Agusta F4 750
05 999R
06 SC1000
07 1098
08 M696
2003 M1000s
« Reply #9 on: June 30, 2008, 01:37:43 PM »
-M
Noooooo - keep it air cooled.  It would be a lot harder to get a radiator and the plumbing to look good on the 696.
 moto
Spider
« Reply #10 on: June 30, 2008, 04:44:56 PM »
 moto
no one, not even Moto, can make those radiators look good. A motorcycle made love to a fridge, your bike is the love-child, deal with it  Grin
I like the swing arm on the 696 - and imagine when Dicati tgurn the 'Italian design' knob up to 9 or 10 for the bigger 'premium' bikes - it will look hot!
« Reply #11 on: June 30, 2008, 05:38:31 PM »
Maybe...
I've wondered before whether, given enough motivation, a 4 valve motor could be fitted to a monster with a Benelli-like underseat radiator? You'd still need to do a nice job of the plumbing, but even that's do-able, my brother used to have a VT250 Honda that used the frame as part of the plumbing system - I dunno quite how well the material Ducati use for the frame tubes would take to having coolant run through it, or whether there's anything else attached that'd be concerned by the extra heat, but I'd like to see someone try :-)
big
moto
« Reply #12 on: June 30, 2008, 11:03:48 PM »
Maybe...
big
It would be a blast to put a torquey 1098 motor in the new Monster frame.
I think the radiator can be hidden better than it is on the S4R and S4RS. We looked at having long narrow radiators made for the S4R and S4RS at one time.
Black hard pipe and black silicone hoses would  look better than what is on the water cooled bikes now.
Underseat radiator would look great. Might be a hot ride though...
-M
« Last Edit: July 01, 2008, 11:02:28 AM by moto » Logged
www.motowheels.com
96 M944
98 900SS FE
01 996R
02 MV Agusta F4 750
05 999R
06 SC1000
07 1098
08 M696
« Reply #13 on: June 30, 2008, 11:26:53 PM »
They get away with underseat exhausts, it can't be _too_ different a problem heat wise...
The picture in my head has standard-looking low mount exhausts (or possibly S*R side mounts), with the seat modified to be rider only, and the space from the cowl down (where the pillion seat and the back of the subframe goes) reused for the cooling system - a long skinny radiator that goes diagonally, starting down near the back of the riders bit of the seat, and extending backwards up to near the top of the taillight. I'm guessing the stock sidepods could be modified as air intakes (though if you were doing it "properly" you'd probably source the cool air from right up near the headlight and duct it between the tank and the airbox lid...) Getting the hot air out would be easier, either around the taillight, or, since I've already given up the pillion seat, through louvres in the top of the set cowl, though my dream has it looking as close as possible to a "stock old school" Monster, so I prefer the idea of a pair of small-ish round tail/brake lights suspended in the radiator exhaust duct...
'course _I'm_ only dreaming, not trying to work out how to pay for this kind on work  Grin
big
Spider
« Reply #14 on: July 01, 2008, 03:57:51 PM »
Iain, you're going to have to add 'mad professor' to your title.
Fantastic ideas!
 waytogo
Pages: [1] 2 3 ... 7   Go Up
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC
