May 21, 2013, 03:56:07 AM *
  Home   Forum   Help Search Login Register
Pages: [1] 2   Go Down
Author Topic: Hesa Fire Headlight  (Read 8754 times)
nkryptit
« on: July 18, 2008, 11:18:27 AM »
http://xpostreetfighter.com/detail.aspx?ID=26
$260 is not a bad deal, right?
What do you guys think about that on a 696..I feel like the current headlight is to wide, I like this minimalistic look a lot better.  Feel free to post any other suggestions.
CDawg
S4RS
« Reply #1 on: July 18, 2008, 01:10:23 PM »
CDawg
S4RS
« Reply #2 on: July 18, 2008, 01:17:25 PM »
PIAA also makes some great lamps that just screams out to be customed:
http://www.shopatron.com/product/part_number=3051/353.0.10544.0.0.0.0
http://www.shopatron.com/product/part_number=9194/353.0.10544.0.0.0.0
http://www.shopatron.com/product/part_number=1490/353.0.10544.0.0.0.0
http://www.shopatron.com/product/part_number=73082/353.0.13763.0.0.0.0
*I have no financial interest in PIAA, just love their design
flanman
« Reply #3 on: July 18, 2008, 01:34:22 PM »
CDawg how hard was that to wire? Is it just a plug and play or is more required? Any other pics you might have would be appreciated thanks  waytogo
nkryptit
« Reply #4 on: July 18, 2008, 01:59:37 PM »
What did you use to mount that with?
CDawg
S4RS
« Reply #5 on: July 18, 2008, 02:10:58 PM »
Wiring: It was pretty close to plug and play.  Mine had minor wirign issue which I cannot remember if it was their mistake or my mistake.  I had to wire in the parking bulb to the LEDs and I had to fiddle the hi/lo wires, but frankly I could have been the one that screwed it up by playing with it woo much
Brackets: I retained the stock bracket and added (makeshift) spacers from Home Depot.
squidwood
« Reply #6 on: July 18, 2008, 03:10:19 PM »
looks like the lighting part of the acerbis cyclops headlamp without the mask.What is the power output of this unit?Does it compare with the stock lamp or exceed it.I found the cyclops unit to be weak.I live in an area where there are no streetlights and deer/elk/wildlife is common at night.Must see before I plough into something.
Please advise.
CDawg
S4RS
« Reply #7 on: July 18, 2008, 03:17:37 PM »
What is the power output of this unit?Does it compare with the stock lamp or exceed it....I live in an area where there are no streetlights and deer/elk/wildlife is common at night.Must see before I plough into something.
Materially brighter than stock.  I don't know the wattage off hand.  I don't ride at night much, but with the low and the high can be both turned on at the same time for good light.  If you live near wildlife, I would also consider going HID which is the brightest option right now.  The Hesa is halogen.
Binary
« Reply #8 on: July 18, 2008, 06:37:35 PM »
What will you do for the indicators on the 696? Handle bar lights? I think the headlight swap will look sick! Good luck!
2009 Monster 696 - Dark
« Reply #9 on: July 18, 2008, 07:11:25 PM »
These with the Mirror-mounted turn signals!
1998 ST 2  -- Specs: Stock
2009 Monster 696  -- Specs: 1198 forks with Ohlins and Racetech internals, S&P Triples, S&P Rearsets, Custom light, Superlight sprocket, Woodcraft Clipons, DP ECU and Air filter, R&G Tail Tidy, DP Comfort Seat, Custom paint with 80's skins, Michelin Pilot Road 2CTs, Braking 15mm offset wave rotors, removed underframe bodywork, CNC'd blackened sprocket cover, DP Steering nut. Billet Lightweight Flywheel, 2into2 custom Megaphone Mufflers, PC V
TAftonomos
is without a monster :(
« Reply #10 on: July 18, 2008, 09:41:44 PM »
Where is the HID one available?
CDAWG, how is the cutoff/patten on the halogen light unit?  Might be cheaper just to buy that and retrofit it w/hid if the cutoff is sharp.
Then again, you could buy this:
http://www.xpostreetfighter.com/detail.aspx?ID=57
And retrofit a nice HID w/projector in there.
« Reply #11 on: July 19, 2008, 12:22:16 AM »
looks like htere already is a projector  lens in there.
Does anyone get this trend...
Stock round healight = huge fly
stacked ontop = alien (i think of command and conquer 3, the scrin's walking thingys)
Side by side aka duals = the simpsons eyes.
Duals with angel eyes = an actual fruit fly
Check out my Latest Blog : http://kuixihe.com/CNY1
knightrider
« Reply #12 on: July 19, 2008, 02:28:24 AM »
yep, but just like a reflector housing that projector is aimed for halogen bulbs.  although projectors ussually dont suffer from horrible glare as much as reflector housings when you stick a hid bulb where it aint supposed to be. Cheesy
 the other question, cuz i like the looks of this thing, where will i hide all those wires my stock headlight is hiding now. haha.
1994 M900
Alexandre
Monstro
« Reply #13 on: July 20, 2008, 07:08:30 PM »
more pics, more angles?
thanks!
Murdered Monster
« Reply #14 on: August 08, 2008, 08:11:02 PM »
+1  I'd love to see some more angles and close ups. Like my 3 year old says, PLEASE!!!!  Bike looks great!
« Last Edit: August 08, 2008, 08:12:42 PM by ryanspencer74 » Logged
'09 M696 Dark
Pages: [1] 2   Go Up
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
