April 24, 2024, 02:49:45 PM *
Author Topic: How to affix stickers  (Read 6182 times)
CDawg
S4RS
« on: July 21, 2008, 06:23:54 AM »
Clean the surface you want to affix a sticker on.  Next peel the backing off the sticker.  Take windex and spray the sticky side of the sticker (no need to over saturate, just a good misting).  You can now put the sticker on the surface.  Because there is Windex on the back, the sticker will slide around as if it was on soap.  This allows you to move the sticker to the proper position.  Once there, then apply pressure from the inside of the sticker to the outside, squeezing out the excess Windex.  Since Windex also evaporates, the sticker will slowly become more and more sticky.  Diligently and slowly squeeze out any bubbles .  After about 1 minute, the sticker will be completely adhered to the surface.  Let sit for a few hours and you should have a solid seal!
whaler
« Reply #1 on: July 25, 2008, 06:12:59 AM »
+1
I'd like to add that if your doing a large sticker, like say a motocross graphic, use a plastic squeegee to help you get the air bubbles out. (You can get them for around a $1 at any auto parts store. It also helps to spray a fine mist on the top of the sicker when your doing this, helps the squeegee slide better without harming the sticker.
CURRENT
2001 Ducati Monster 750 (red) 2004 KTM 450SX (supemoto converted) 1999 Yamaha YZ400F (Street Legal supermoto converted) 1995 Suzuki DR350 (supermoto converted) 2001 Honda XR50
FORMER
1999 Suzuki SV650 1999 Yamaha R6 1986 Yamaha YZ250 1981 Yamaha Virago 750 1986 Honda Knighthawk CB650SC 1995 Yamaha Blaster 1983 Kawasaki KX7HP (old KX 80 I shoved a 7hp snoblower motor in)
otter1
« Reply #2 on: August 28, 2008, 10:16:23 AM »
I managed to tear the vinyl white stripe on the rear seat cover. I just ordered a new one from the dealer ($27) + tax and some shipping fees. Should I use a hair dryer to warm up the stripe, remove it, and then use windex to position the new one Huh?? Thanks.
CDawg
S4RS
« Reply #3 on: August 28, 2008, 11:15:11 AM »
Yup.  Then you can use Goo-Gone to clean up the old gunk before windexing.
Airborne
Crash n' Burn
Monster S2R 800 - ALL BLACK
« Reply #4 on: August 28, 2008, 01:13:20 PM »
The goo gone i have says not to use on paint? Are their different varieties? Maybe mine is just whack.
CDawg
S4RS
« Reply #5 on: August 28, 2008, 02:49:24 PM »
I haven't had any issues, but you should always test in a concealed spot.
otter1
« Reply #6 on: August 29, 2008, 07:48:02 AM »
Thanks for the quick responses. I was happy to find this link because I was not sure how to accomplish replacing the stripe and not have it turn out looking worse than it already does. I will re-post with a few pics after I get the part in and try replacing it. Dealer says expect it to be about 2 weeks for it to arrive.
