NGK VS Champions
Started by desmodoktor, February 26, 2011, 11:04:06 AM
desmodoktor
Recently bought the NGK DCPR8E spark plugs.. (didnt know the cap is removable ) Today went to the dealer and bought the original ducati champions.
which one should i put on? right now i have the Champions on. Am i going to see/feel any difference if i put the NGKs on?
IG @desmodoktor & @ridingturtlegarage
Düb Lüv
NGK's i've always been happen with them in cars and in the Duc. right now i think i have the ones as you, but going to bump up to iridiums come this spring.
Building, building, building
booger
Those iridiums won't perform any better than standard plugs, just cost more. Won't see a difference with NGK vs. Champions either. Go with whichever costs less. I've used NGK iridiums and saw no difference between them and the original Champs. One fouled out so I replaced both with I-can't-remember but they work fine too. Not a whole lot of difference, but the marketing does get you excited doesn't it.
2001 M900Sie - sold
2006 S2R1000 - sold
2008 HM1100S - sold
2004 998 FE - $old
2007 S4RT
2007 Vespa LX50 aka "Slowey"
2008 BMW R1200 GSA
Langanobob
It seems to me that I've had more trouble with Champions than other plugs.  Of course I don't have any documented statistics but it's happened often enough that I avoid them.
I never had trouble with the OEM Champions, but when replacement time came...read service, the dealer replaced them with NGK.
I think it had more to do with cost of OE Duc Champs vs over the counter NGK.
I have a lawn mower with 20 years on a Champion plug. There isn't anything wrong with either.
desmodoktor
I paid 4$ for the NGK DCPR8E and 8.8$ for the Champion.
the only reason i got both was because i didnt know i can unscrew the cap so it fits on the wires..
oh well .. i ll keep it original , im going to use the Champions.  :)
Gimpy
#6
My car came with 4 fancy iridium plugs from the factory.  They last longer, but they had better at $9.50 a piece.  I replaced them with the standard NGK plugs.  I have seen no noticable change in power and no difference in gas mileage.
Once I win the lottery I will buy a dyno and spend all my time gathering evidence that is not anecdotal at best.  Till then I'm gonna save the $16 bucks when I can, so I spend it on  [drink]
