Low Fuel sensor gasket replacement???
Started by djrashonal, February 06, 2010, 06:27:08 PM
djrashonal
Hey everyone. so at first I thought my tank was leaking, upon further inspection, it seems to be coming from the gasket that is surrounding the wires coming from the low fuel sensor. can I replace that? or am I stuck replacing the entire low fuel sensor?
Hi Res Shots: http://gallery.me.com/afakhori/100372
thoughts?
thanks
Also, is it a bad thing that I just put gorilla tape around it for the time being?
01 SSSSSSS4 - Sold
'09 Triumph Bonneville
S2R800 dark - searching for
The gasket comes as a spare part.  If it is the nut that is leaking you need to buy the whole sensor from Ducati but you can find an aftermaket nut at  http://www.ca-cycleworks.com
Replacement Fuel Sender Nut     All pre 2003     fuelnut     $29.00    add to cart
The nut is made from billet so it will not fail.
...and if it's leaking around the wires through the epoxy you'll need to replace the sender.
djrashonal
Thanks Howie for sourcing that nut! But it seems DP is right, since it's leaking through the epoxy onto the wires I believe I need to replace the unit, Though I will be purchasing that nut as a precaution.
Does anyone know where I can scrounge up a low fuel sensor unit? i found a couple on ebay, but i didnt know if there were any aftermarket versions. thanks!
01 SSSSSSS4 - Sold
No a/m that I'm aware of.
There was a thread around not too long ago where someone cobbed something up...but I wouldn't have gone that route.
djrashonal
Quote from: ducpainter on February 07, 2010, 07:40:13 AM
thanks for the heads up, I think im gonna stay away from making my own and just grab it when I find a good quality one on ebay, or if someone on the board has one first. thanks again for the help!
01 SSSSSSS4 - Sold
