can any one ID this ECU?
Started by trippin, March 25, 2012, 08:02:25 PM
trippin
sorry my first two posts are questions, maybe i'll be able to help out with tech later once ive worked out a few things.
anyways, can anyone id this edu? i know its magnetti marelli. but i think its aftermarket, or been unlocked/flashed.
brad black
it's a 5.9m to suit a monster s4 running 006 mapping
Brad The Bike Boy
http://www.bikeboy.org
trippin
i have no idea what that means.  is it stock? does 006 mapping mean anything?
really appreciate your help, i was pointed here from another monster forum where my tech questions were unable to be answered.  thank you.
trippin
through a little more research it seems the ecu is bone stock, and the only reason i would see wet plugs is due to a kink in the return fuel line.  when i get it back together with the correct spark plugs, and the rest of the alternator case rebuild, i will be very picky about the fuel line routing.  it was routed under the battery tray over the rear cyl head.  i think this may have caused some running issues.
