30K Service time!
Started by the_Journeyman, August 30, 2008, 07:46:02 AM
clubhousemotorsports
fork oil and shock oil
wheel bearings as well
+1 on needle jets
darkattackdog
Quote from: the_Journeyman on August 30, 2008, 08:06:55 AM
You're always good & helpful DP, you know that?
Good suggestions, I've not checked either.  I'll add that to my list, thanks!   [thumbsup]
JM
bromance?
Quote from: darkattackdog on September 08, 2008, 10:30:01 PM
e-bromance?
Fixed it for ya.
Quote from: the_Journeyman on September 08, 2008, 07:47:08 AM
I always grab the lowest grade at the pump.  I ran some Seafoam to try to clean everything up a bit.  I'm going to order some replacement needle jets (these are the same thing as emulsification tubes, right) and take care of that.  The plugs indicated a slightly rich environment though, which isn't helping ~
JM
yeah...same thing. That should cure your rich condition.
