lifespan on S4Rs stock clutch
Started by jesse370, September 01, 2008, 11:54:52 AM
What gear did you try to bump start in?
Second is recommended.
Not that twins don't suck to bump-start anyways.
LA
Yea, second works, but if you have really killed the battery - to the point that you don't have the voltage to power the fuel injection, if ain't gonna work anyway.
LA
jesse370
so second is what I needed....
The battery had juice, it could prime the system...Just not enough to start the bike. I eventually got a jump from someone....AND jumping a monster BTW....
make the beast with two backsing SUCKS
White S4Rs | Ducati Performance Chip | Termi's | Hyperpro side mount damper | Motowheels MW-7000 Slipper | Billet Clutch Cover |  Speedymoto Ti Spring Caps | Speedymoto Stainless Springs | STM Frame Plugs | Ducati Performance Seat | CRG Roll-A-Clicks
jesse370
So the bike is still in the shop  :-[
It was supposed to be done today but they forgot to do the rear tire as well....Not sure how you would be able to TEST RIDE my bike without doing that?
OH thats right they DIDN'T! When I talked to the dealer and asked about my bill cause it seemed low, he said...."shit your rear tire"
So I get a call a few hours later, they were taking the rear tire off and a bunch of my drive pins on the rear had sheared off. They were installing new ones for no charge I just have to pay for them.
SO how common is it for these pins to shear off?
BUT this weekend I will be making a new post with motowheels slipper clutch pron.....
that is IF I can get off my bike for long enough first.  8)
