Fuel Breather --> Can I get rid of this stuff?
Started by Paegelow, September 03, 2008, 04:32:43 PM
herm
Quote from: arai_speed on September 11, 2008, 09:42:35 AM
Is the procedure similar on an S4R (2000 +) model?
The diagram for my bike is a bit diff:
From the looks of it:
5 and 9 go in the trash
12 get plugged?
Plug the throttle bodies on each side??
nope,.... you want that to be open so the fumes caused by evaporation can escape.
just run it down the same place that # 22 is
herm
not positive on the 696, but its M10 on the other models
http://ducatimonsterforum.org/index.php?topic=3446.0
ok here's the FAQ that states M5 bolts. errr gotta run to the store now. wanted to do this tomorrow night.
herm
El Matador
Paegelow
Quote from: teddy037.2 on September 11, 2008, 09:22:04 AM
following the two lines from your can should lead you to the intakes.
IIRC, horz is on the RH side of the bike, vert is on the LH side, and it's a squeezey fit through the frame
Aha, I found where they're supposed to be.  I was sort of confused because there were no lines there to begin with.  It would be right before the intake meets the cylinder head itself, right?
Turns out they were already plugged with some little socket head cap screws.
Funny, it seems like someone already went to the trouble of plugging those holes and removing the lines, but they never got rid of the canister!
herm
ok did the removal on the 696. definitely not M5 bolts. didn't bother to try the M10 just got covers for the valves.
need to still rerun the vent hose. have to find the Y with two different sizes since the vent and the overfill lines are different. although i didnt check inner diameter, so i may be wrong.
Paegelow
It's not M10.  That would be way too big.  The threads on the end of the rear view mirrors, where they screw into the bracket on the handlebar, is M10!
herm
take the screw with the air inlet in it down to home depot and size it.
or, you can read the how to here...
i bought M5 .80 x 10 screws and they are not the same size as the plugs. for certain. on the 696
