December 24, 2024, 09:49:31 AM
new 696 mods
Topic: new 696 mods (Read 24954 times)
nkryptit
Re: new 696 mods
Reply #15 on:
September 05, 2008, 12:20:47 PM »
Quote from: rsy on September 05, 2008, 08:58:09 AM
Just wondering how much sh*t you get to your back/helmet on wet/muddy roads after that tail chop ?
Wonder no more...Quite a bit...I rode home from work for lunch, it was a bit moist from some earlier rain... I had to change my pants and shirt (because some of it was sticking out from under my jacket) before I headed back.
nkryptit
Re: new 696 mods
Reply #16 on:
September 05, 2008, 12:22:42 PM »
Quote from: lazarus7 on September 05, 2008, 11:02:58 AM
took about 30 min this afternoon, when i could see better...
it took loosening both mounting bolts on each carbon canister,
where the L bracket mounts the cans to the frame,
to allow enough play to move the cans upward and forward slightly
to meet the higher mounting point on the hanger....
its a small/ subtle change, not a dramatic as you might think....
judge for yourself....
That is not much difference at all...Oh well...Looks beautiful either way!
MOUSEMAN
1992 851 2009 M696
Re: new 696 mods
Reply #17 on:
September 17, 2008, 08:19:27 AM »
Quote from: NekkedChic on September 05, 2008, 06:56:53 AM
OHHH tks SO much!
I tried to have my dealer put on some Pro Taper bars, but the wires and cables were too short. I also am a shorter rider and in need of risers or bars. The Rizomas look great. Will try them eventually.
1992 851 2009 M696
NekkedChic
Naked Bikes-u dirty boyz!
Re: new 696 mods
Reply #18 on:
October 08, 2008, 05:00:42 AM »
Quote from: lazarus7 on September 04, 2008, 06:10:15 PM
those rizomas are a straight swap,
and DO have quite a bit more rise/ reach to them....
definitely puts you in a more upright/ back position
the control pod on the right hand side, the starter button pod, needed to be rolled SLIGHTLY upward
so that the bars completely clear the tank indents on both sides as cleanly as stock....
no probs, a clean straight bolt-on....
do 'em, youll love 'em....
and enuff cable lines/room??? Brake lines look plentiful tho.
Ducatista Barista
lazarus7
Re: new 696 mods
Reply #19 on:
October 08, 2008, 10:23:53 AM »
plenty of line for full turns lock to lock with no binding.....
piece of cake.
"...the greatest artists indulge in a 'culpable rivalry' with God." Stanislas Fumet
geoffduc
18 till i die
Re: new 696 mods
Reply #20 on:
October 08, 2008, 11:53:26 AM »
it's looking good Lazarus,now how about rizoma grips and bar ends to really finish it off.called in at ducatimanchester today and they have in stock a pearl white hyperretard,looked quite nice but i prefer my own red retard.also in stock a pearl white multi,it looked BIG.
BTW your toy box is getting really full.
2015 scrambler FT
2009 monster 1100s
j|rz44
White 696
Re: new 696 mods
Reply #21 on:
October 09, 2008, 11:45:37 PM »
quick Q on the exhaust..
how do i get the baffles out?
the nut is spot welded on and the bolt is tight squeeze...
need a special tool?
thx and nice bike
Life Is Good
dutchy73
Re: new 696 mods
Reply #22 on:
October 10, 2008, 08:07:14 AM »
Quote from: j|rz44 on October 09, 2008, 11:45:37 PM
thx and nice bike
The bolt has an allen head... It's just one holding the baffle in, so take the bolt out and use a pair of needle nose pliers to remove it. Make sure you mark which baffle comes out of which can, just in case you want to put them back in for some reason.
'09 696 Dark, Termi, Rizoma, CRG
j|rz44
White 696
Re: new 696 mods
Reply #23 on:
October 11, 2008, 12:59:27 AM »
got it, thx man
Life Is Good
lazarus7
Re: new 696 mods
Reply #24 on:
October 11, 2008, 06:31:48 AM »
oooh , youre gonna love the way they sound....!!!!
j|rz44
White 696
Re: new 696 mods
Reply #25 on:
October 12, 2008, 02:09:43 PM »
you werent kidden!
Life Is Good
lazarus7
Re: new 696 mods
Reply #26 on:
October 13, 2008, 06:09:31 AM »
ohhhhh yeah......
Jimmy Ducati
Re: new 696 mods
Reply #27 on:
October 15, 2008, 05:25:59 PM »
Are those regular or conical Rizoma bars? I am assuming regular.
I am having a guy knock off the Rizoma's in thick guage Ti unless someone
knows of a better brand/set to dupe? He is charging me $200 for the set.
If anyone else is interested let me know, and perhaps we can get a bulk
discount. Nothing rides like Ti
lazarus7
Re: new 696 mods
Reply #28 on:
October 16, 2008, 05:04:00 AM »
regular, which IIRC is 22 mm....
the difference between regular and conical bars, and hence the name,
is that conicals are larger in diameter in the center, clamping area, to fit a larger riser/ clamp
for a stiffer overall bar....
for example, my s4rs had a conical bar,
the 696 is a traditional bar, which i BELIEVE is 7/8", 22mm.......
replaced this one with a standard 7/8 22mm rizoma red billet....
and as to the knockoff TI, this bar has a great shape,
perfect reach and rise for a more relaxed and upright riding position...
Jimmy Ducati
Re: new 696 mods
Reply #29 on:
October 16, 2008, 05:25:27 AM »
Thanks Laz!
I ordered my custom Ti bars today.
The guy said he will bend them tonite,
and have them shipped tomorrow.
I will post pix when I install.
Last Edit: October 16, 2008, 03:12:23 PM by Jimmy Ducati
