Power Wheelies
Started by flanman, May 08, 2008, 05:21:14 PM
univox
Quote from: tufty on May 13, 2008, 05:12:04 AM
"the radiator for a S4R is $1600, the tank for a S2R is $1300, my full Arrow exhaust cost $2000...."
Startling old ladies with your hooligan antics: Priceless
Ducatiloo
It's only a cure if you don't have the sickness.  [thumbsup]
750 SS 01    800 S2R 05  Aprilia RST 1000 futura
spinned
I like to wheelie, but I usually do it on some back road.  A friend of mine gets a little spirited though and he does it off the line at city stop lights.  Certainly scares the grandmas, delights the teenagers and anyone else coming out of a starbucks, but probably not too smart to do in traffic.
A.duc.H.duc.
Quote from: spinned on May 13, 2008, 08:10:02 PM
I've been known to bring the front up a little at a light... never when someone is in front of me though.
brownwhale
I have a M900 that refuses to not wheelie
I prefer 1st gear power wheelies, accelerate quickly to load rear, soon as you enter the powerband, which is quickly on these twins, drop off the gas, let the weight transfer to the front and forks compress, as the forks rebound, quickly flick open the throttle, a little a first then more and more as you get comfortable, I personally don't worry about the rear brake since I'm not 12 o'clocking and the engine has enough compression braking that a quick release of the throttle will bring you back from even very high wheelies
now ask about stoppies and seat stands :)
CNS-Mike
Did my first wheelie on my '07 S2R today - Hizzou!  [evil]
Man, you know it's good if you're still smiling after having your nuts smashed.
I'm 6' 4" 260 and all it took was to follow everyone's advice...get rolling in first, chop the throttle back and then go  WOT - no clutch needed (although, I'll admit I didn't get it all the way open before I rolled off - thus the squashed nuts).  Oh, and I did it in the Lowe's parking lot when no one else was around...so I guess the only thing I would add to this post is that you should make sure you remain mindful of your sack while messin' around with wheelies.
That was like 6 hours ago and I still can't wipe this S.E.G. off my face.   ;D
I've been riding for close to 14 years (with time off while overseas) and I've never pulled a wheelie until today.  Oh yes, there will be more...
2007 S2R1K - Chopped tail and emissions can; 14T front, Vizi-tec LED tail light, HID, CRG lane splitters
Sold - 1998 Honda Shadow Aero  ***  Crashed - 1980 Yamaha XS1100  ***  Killed - 1978 Yamaha XS750
mxwinky
My old Monster 620 would wheelie with a bit of clutch work in 2nd gear so don't think your 800 won't.  Start off in 1st, engage 2nd, hold the throttle steady and fan the clutch. (flick the clutch, zap the clutch, whatever terminology you like)  You should notice the front end pop up, even if just a little.  With practice (find a nice open area) and patience you should be able to get the feel for how many revs to give it and how fast it'll come up.  Cover the rear brake and be ready to stab it to bring the front wheel down if you feel it's getting too high too quickly.  Don't say I didn't warn you.
Now if you want to avoid all that work, go for the S4RS.  Gad, my new Tricolore will wheelie at darn near any speed in any gear.  It's highly addictive!  I can't wait to see how much gnarlier it is this weekend after the Termis and the ECU are installed.  She's in the shop right now for the mod.  Eeeevil!
jesse370
Quote from: mxwinky on June 10, 2008, 09:46:15 PM
get ready man... [evil]
my Rs with the pipes and chip and air box will pull the wheel going into 4th if you are a little slow on the clutch. first gear power wheelies are a little too nuts now, it just yanks the bike up, I tend to play in 2nd now.
White S4Rs | Ducati Performance Chip | Termi's | Hyperpro side mount damper | Motowheels MW-7000 Slipper | Billet Clutch Cover |  Speedymoto Ti Spring Caps | Speedymoto Stainless Springs | STM Frame Plugs | Ducati Performance Seat | CRG Roll-A-Clicks
blue tiger
I will attest that any "whacking" of the throttle in second (s4rs full system/airbox.ecu) will = wheelie. In first....forget about it. I find the front end of mine getting curiously light through the first three!!! Gimme a slight rise in the road followed by a little downhill...fun...fun...fun. I was close to pulling some 2 wheel air a few weeks ago !!!
I'm here to kick a*! and chew bubble gum...and I'm all out of bubble gum.
Pancake81
#24
The Monster wheelies very well in my opinion. It's just a different technique than inline 4's or 3's. I like to compare them like the Twins are 4 stroke dirt bikes and the I4's are like 2 strokes. The only issue with the monsters are that you need a big bore (800 or higher) to get the super nice wheelies out of them and rev limiter comes quicker. Because the rev limiter comes quicker you need the lower end grunt to pull you up at lower revs to carry the wheelies longer.
Then you cross the bridge of changing gears through out the wheelie (I personally dont prefer this on stand-ups because of the awkward way your foot needs to work on the shifter). In the vids I posted earlier I brought it up in 3rd and held it at the balancing point until I wanted to come down (no shifting). This is a good technique to start with because then you know you will not be exceeding the top speed of the gear you brought it up in. The balancing point gives you that kind of "clenching" feeling that takes a bit to get used to though. Remember, its better to put it down then to go down (rebuilding forks can be expernsive, but a new bike and road rash isnt worth your trouble to look cool).
When I do like to change gears is during sit down wheelies. This way your foot hits the shifter just as it would when you are riding normal. I personly like to bring it up in second; by slightly "floating" my butt above the seat, then sitting back down when the bike is up. In my opinion this technique should be learned second for alot of reasons.
1) Its easier to slide off the back of a seat onto the road than it is when your standing on pegs.
2) Its hard to see the road ahead of you when your gas tank is in your face (this is when your at the balancing point (BP), not just floating the tire a foot or two above the road for a few seconds. Where as standing you can see all around you.
3) Stand up wheelies give a "safer" perspective of the BP than sit downs if your learning
4) When it comes time to put the bike back down on 2 wheels it truely is an art to do it gracefully. So when you do it hard on a stand up your arms in conjuction with the suspension absorb the impact. Where as on a sit down: riders are more common to hit hard... slide forward into the tank... resulting in pushing the handle bars... and worse case scenario getting a speed wobble :'(
5) Also, once you learn how to hang out at the BP and change gears together, to many people go from 2nd to 4/5/6th and dont have the skill to successfully bring the bike back down at high speeds.
Earlier I mentioned you need the Big Bore Ducs to wheelie. This is not a slap in the face to you members that dont own one 8) . Its just means sometimes more power is better than not enough. I just bought my S4 this year... Prior to that I owned a 02 620. Did I wheelie it? You d**n right I did. But it took more finnese, skill and BALLS than the S4. For those of you checking out these pics and vids that want to go out and learn to wheelie the most important advice has been said time and time again on this board.
1) LEARN ON DIRT!!! Because I dont want any monsters injured in the process
2) Go to youtube and type in "Wheelie Crash" :-X . Make sure you thats what you want, because those are possible outcomes whether its your first day of wheelies... or or your 5th year of wheelies.
3) Dress for the Crash, not the Ride.
If you go on youtube abd search for monster S4 wheelies by Pancake81 you can a few I did last year. For some reason it wont let me post the linky.
Heath
About the same time you're dragging your knees through a series of tight left-right-handers on Sunday afternoon, some guy in white shoes is sweating a 3-foot putt. Go figure.
DucatiBastard
+1 from CNS-Mike on taking care of your nuts, first time I wheelied on my monster it took me by surprise so i chopped the throttle real qiuck=nut crush, thankfully i was in 1st and not going very fast, but BEWARE! For sit down wheelies, squeeze the tank real hard to protect the jewels
Give a man a beer, and he wastes an hour.
Teach a man to brew, and he wastes a lifetime.
2006 Ducati S2R 800, 2004 Honda Dream 50R, 2001 Kawasaki W650, 1940 BSA M20
VeryMetal
When it comes to stunting, especially anything involving a balance point ie: Everything  ;D I prefer to get used to trying stuff on a smaller (less expensive bike). If you have the money, don't be too afraid to go and throw your bike around, just keep the speed down, concentrate on technique and don't try to use speed as an advantage. You can slap the concrete a lot harder and have a lot less control over where you and the bike end up at higher speeds. If stunts are really important to you, it's worth the effort and the spills. You can pick up an older 4 cylinder honda or something (for cheap) that will wheelie like a mf and won't cost you a penny when you drop it. Learn stuff on that then apply it to your nice bike. It's a lot less likely to end up in the shop/ garage.
I practice on dirt bikes that my friends own, not great for stuff like high chairs or tank stands but do the trick for wheelies/ stoppies etc.. I'm not afraid to drop them and their power to weight ratio is great for learning, can be a bit much sometimes. I'm no expert but this is just my two cents. As for the different engines and handling, once you have confidence with the maneuver it's not that hard to adjust to different set ups.
2002 Ducati Monster 750ie Dark
2005 Monster S2R Dark
How do you guys bring wheelies down? I've been doing massive first gear power wheelies that i can only bring down by letting of the throttle and gasing it on the way down again. I'm too chicken shit to step on the rear break.
Ducatista
Quote from: He Man on July 04, 2008, 10:04:37 PM
When doing those kinds of things, the rear brake is your friend.  Just go easy on it.  Don't stand on it.
carbon fiber Superbike front fender, bar end mirrors, floating cast iron rotors, carbon fiber chin fairing, Cycle Cat frame sliders, Arrow carbon fiber low mount slip ons, Rizoma billet cam belt covers w/ plexi windows, Rizoma billet front sprocket cover, billet handlebar clamp, carbon fiber rear hugger, tail chop, open air box, Corbin seat, stainless clutch springs w/ black keepers, suicideless sidestand bolt, Evoluzione clutch slave cylinder
www.myspace.com/bitgoddess
Carman
I haven't got comfortable with the clutch method yet, little by little I'm getting there.  Roll on is much easier and more graceful.  Of course the clutch will get you there right away, just takes time and practice.
Carman
'07 S4RS
