The 3 Gun Cabinet
Started by Mother, September 12, 2008, 04:52:52 AM
Quote from: Mother on September 12, 2008, 02:21:51 PM
that sure beats the $900.00 RRA
talk to me about the pro/con of the 1 in 7 twist over the 1 in 9
depends on which 5.56 ammo you are using.
if you are using 55 gr SS109, the twist should be 1:12, but for various reasons the 1:9 and 1:7 are used with good effect with the heavier ball currently used (62 gr).
the main advantage of the 1:7 is for the M4 barrel which is 14" of rifling.  but mainly for heavier (>60gr) projectiles.
COWBOY
Forgive my newb question here I am certainly no gunsmith.    I thought the advantage of 1 in 7 was that it spun faster and enabled using heavier ammo with better effect?   Why would you want to use 1 in 12 as opposed to it?
2005 S2R -- Mods installed: DP termi full racing kit, ST4 Forks, S4R rear shock, 999 Radial Brake and Clutch MCs, 4 pot Brembo Calipers, 320mm Snowflake rotors, SBK Quick change carrier, 43T rear sproket, Tomaselli Clip Ons, Cyclecat Frame Sliders, ASV Levers, zero indicators, Supernova taillight
Sinister
Quote from: COWBOY on September 14, 2008, 11:09:23 AM
Note that he mentioned a 55-grain bullet with regard to the 1:12 twist.  With greater bullet weight (65-gr, etc.), a 1:7 (in M4 barrel lengths) or 1:9 is preferred.
"...but without a smiley, some people might think that sentence makes you look like a homophobic, inbred prick. I'm mean, it might leave the impression that you're a  douchebag or a dickhead, or maybe you need to get your head out of your ass."  DrunkenMonkey
"...any government that thinks war is somehow fair and subject to rules like a baseball game probably should not get into one." - Marcus Luttrell
Depends on the projectile weight.  55 is the old weight, 63 is the new, so the SP1's had a 1:14 turn with a 55 gr projectile, but now the issue is 63 gr with a 1:7 or 1:9 turn depending on the barrel (M16 vs M4 etc)
Quote from: Sinister on September 14, 2008, 12:38:02 PM
...what he said..
c_rex
so is there some sort of "optimal" algorithm for gm/twist?
Quote from: c_rex on September 14, 2008, 05:46:20 PM
no
it is a function of your projectile, powder load, broach depth and probably a dozen other things you'll never figure out even with the best voodoo.
trial and error.  if you reload, then you can tune your ammo for your twist, but generally it's better to have a slower twist with a lighter projectile and faster (and hotter) with heavier.
Mother
Quote from: ducatizzzz on September 13, 2008, 07:06:58 PM
Matching calibers defeats the purpose.
in the case of .357 or .44
it means only having to find, purchase, and carry one type of brass
and
can be used to effect in both the short and medium range catagory
note however that in my area, a shot farther thn 150yds is highly unlikely so the pistol chambered carbines are a viable option over the .06 or .308
Mother
Quote from: ducatizzzz on September 14, 2008, 12:40:47 PM
...what he said..
is the new 62gr round having any more single shot effect over the old 55gr round?
or has Irag made it more and more clear that a .30 cal bullet is worth the weight to carry?
iDuc
Some of you people know entirely too much about guns and ammo. ;)
M800Sie
R.I.P. 4/29/07
Sinister
Quote from: Mother on September 15, 2008, 10:48:48 AM
A bro-in-the-know says he's tired of shooting people and not having them die.  He recommends the .308, highly.
iDuc - Your post makes absolutely no sense to me.  ;D
iDuc
My threat level is minimal, and I'm in the 'burbs so the houses are fairly close together. An AR-15 or such would be way over-penetrating for the neighborhood. I'm going old school: a 1911 .45 with HydraShok frangible loads,  a Remington Model 870 12 gauge with .00 buckshot,  and something small and lightweight to carry if necessary ( with proper permits, of course): .38 Special wheelgun??
M800Sie
R.I.P. 4/29/07
Sinister
Quote from: iDuc on September 15, 2008, 01:12:59 PM
I like your plan.  The AR-15 is for the apocolypticon inside of me...must have one!!!
One thought, though: why not use the 1911 for carry (though not small and lightweight, I guess).  I've never been a fan of carrying revolvers, as they are bulkier than semi-autos.  A revolver is a great thing to have around.
kill-wise, no
accuracy-wise, yes.
Quoteor has Irag made it more and more clear that a .30 cal bullet is worth the weight to carry?
6.5 is the new AR round.
Quote from: Mother on September 15, 2008, 10:43:13 AM
i agree with the sentiment, but rarely can you get similar performance out of a longer barrel.  powder is different.
Quoteand
that's a different issue.  but having a long range (or medium) option is smart.
Quote from: iDuc on September 15, 2008, 10:49:59 AM
no, it is that most people know entirely too little.  my brother-in-law is a bona fide hoplophobe.  he won't let his kids in my house despite the fact my firearm collection is in a room safe.  he's an idiot.
Quote from: Sinister on September 15, 2008, 11:46:52 AM
+1 or any round > 80 gr projectile.
for comparison, a typical 9mm pistol projectile is 140 grains weight.  a GI issue M16 round is 62 grains weight.  do the math, regardless of velocity, the 9mm has more weight to hit.  a typical 7.62x51 round has 152 grains (16 grains is about 1 gram)
wheelguns are useful in home-def situations esp urban where break-ins are opportunistic versus planned as in exurban.  check out the Glazer Safety rounds.  any 9mm or above autoloader is also good provided you can control it.
typical AR rounds will not penetrate more than one sheet of plaster (sheetrock) before disintegrating.
shotguns are special and require some practice.  most of us are not used to going through the house with a 3-ft projection (unless we are exceptionally well hung).  shotguns are the best IMHO but require some planning for storage and access.  handguns are easier to secure.
Quote from: Sinister on September 15, 2008, 01:42:36 PM
good point on carrying revolvers.  the J-frames are thinner with 5 rounds, but still are thicker than a typical 9mm autoloader.
the issue iwth autoloaders is just familiarity.  carrying a J-frame is not hard but requires some planning.  you can carry your KelTec P3AT in your belt, but a revolver needs to be in a hip or underarm holster.
Sinister
Okay, let's dig deeper.  Shotguns: autoloader or pump?  I recently acquired a pump, but have hunted with an autoloader for years.  Thoughts?
rgramjet
Pump, less hang ups and you can easily cycle through a bad round.  Plus the satisfying Chick-Chick when you put one in the Pipe!   [thumbsup]
-Sofadriver
