February 02, 2025, 02:48:52 AM *
Pages: 1 ... 41 42 [43] 44 45 ... 106   Go Down
Author Topic: Oz Monster Trading Post  (Read 529898 times)
Dannog
S4RS
« Reply #630 on: August 05, 2010, 07:54:54 PM »
Mmmm I'd be interested in the DP Seat if your looking to break anything up.
BadBoyBubby
You're a sexy woman Flo
« Reply #631 on: August 05, 2010, 09:26:59 PM »
can't break it up, sorry. The old seat went elswewhere.
This signature is forged.
suzyj
Does my bum look big on this?
« Reply #632 on: August 07, 2010, 11:21:16 PM »
Bits left over from my suspension and brake exploits.  Everything is from an '07 695, with 12K mileage.  There's nothing wrong with any of it - I just upgraded for higher zoot factor bits.
  • Stock Sachs shock absorber, with standard spring.
  • Crankcase breather canister, complete with hoses.
  • Suspension linkage rod - non adjustable.
  • Marzocchi forks, with 18mm of spacers (improves sag over stock), standard springs, and fresh 10wt oil.  50/54mm triple diameters, 65mm caliper spacing.
  • 2 x 300mm rotors.  Zero offset, six bolt fitting.
  • 2 x 2 pot calipers.  65mm caliper spacing.  Come with pads with oodles of life.
  • Brake lines to suit 2 pot calipers.
  • Standard coffin brake master (15mm piston), with lever.  Lever is a tad scuffed but perfectly serviceable.
  • Handlebars.  Drilled to move controls inboard by 20mm.
Make me an offer.
Nibor
insanity far outweighs horsepower
« Reply #633 on: August 08, 2010, 09:46:45 PM »
suzy, the forks, rotors and calipers, i'm assuming they all fit together? interested. any idea if it'll swap into a 1998 m750?
or anyone else know what is good for me?
cheers Grin
Nibor
suzyj
« Reply #634 on: August 08, 2010, 09:53:10 PM »
It'd be a little complicated.  From what I've read, earlier monsters have smaller diameter axles, so some mucking around would be necessary to get the forks to play with your wheel.
Nibor
« Reply #635 on: August 09, 2010, 02:01:50 AM »
i'm just thinking if what you have all fits, and the forks fit my triples, then i just need a new axle/wheel to match the forks/discs. suits me well if i can find a reason to buy a newer front wheel, if the axle that suits your forks is hollow. i want some axle/fork sliders, but nothing fits my old style axle. the hollow newer ones however...
tonymtber
"We are going for a ride"
« Reply #636 on: August 09, 2010, 03:01:30 PM »
NEW 14T front Sprocket
Never fitted.  JT Sprockets part number JTF736-14
Will suit Monster 600, 695, 696, 750, 800, 900 & S2R800
Possibly other models as well, best check online if you are not sure.
$20 + postage
Contact me at tonymtber@gmail.com Grin
suzyj
« Reply #637 on: August 09, 2010, 11:34:30 PM »
Don't the older monsters have the speedo drive on the front wheel?  If so, you'd need to organise something to keep your speedo working, as the newer front wheels don't have the speedo drive.
Nibor
« Reply #638 on: August 10, 2010, 01:31:27 PM »
bugger!
anyone got a solution?  laughingdp Sad
the world clearly doesnt want me to have better suspension!
dragonworld.
I can make like a tripod with my.....
« Reply #639 on: August 10, 2010, 02:14:00 PM »
You can still get dramatic improvements in suspension by fitting good aftermarket springs and get the valving redone by one of the suspension shops! I'm sure you can get plenty of suggestions here!? waytogo
With brakes you can get a different more efficient/powerful caliper/master cylinder combo that will match the mounting holes on the fork lower. Grin
The single disc brake on my 750 aint too bad and can get the tyre complaining under hard braking no probs!  waytogo Although it doesnt look as flash as the you beaut, twin disc, multi coloured, all singing, all dancing front ends it does the job quite well.  applause
Aaah the bling disease, once ya got it, ya buggered!  laughingdp [moto]
Nibor
« Reply #640 on: August 11, 2010, 01:57:57 AM »
nope, i have the crappy un-rebuildable forks, cant revalve, i think can only swap springs, oil level and weight Sad
dont get me wrong, it shits all over my 250 haha, and does a good job, but i want a better job.
Dannog
S4RS
« Reply #641 on: August 11, 2010, 10:02:03 PM »
bugger!
yep, just swap out the speedo for an aftermarket one. You'll also need to machine a spacer to replace the speedo pickup
Dockstrada
« Reply #642 on: August 11, 2010, 10:20:37 PM »
I have some Ducati Aluninium spoked wheels for sale, came from a Paul Smart .
Cant see why they wouldn't fit a monster .
If anyone in interested let me know  waytogo
If I wasn't who i was, I wouldn't be who I am !
heatherp
« Reply #643 on: August 11, 2010, 10:46:00 PM »
Yeah you may as well sell the wheels - you don't ride it.    laughingdp laughingdp laughingdp
Dockstrada
« Reply #644 on: August 11, 2010, 10:49:57 PM »
Tru Dat !
Pages: 1 ... 41 42 [43] 44 45 ... 106   Go Up
