Turn Signals baffling me
Started by tankerbutt, September 28, 2008, 04:01:28 PM
Rameses
Quote from: tankerbutt on September 30, 2008, 03:25:42 PM
What the heck is the white block thing and do you think that this is what is causing my problem.  if it is, where can i get one.  the rear signal is an integraded brake, turn signal from clear alternatives.
The white block is a resistor.  LEDs have much lower resistance than a conventional filament bulb.
The lower resistance causes the flasher for the turn signal to basically behave as though there is a blown bulb.
The solution for this is to place a resistor in the system to slow down the rate at which the flasher cycles.
Fix that broken wire and you'll be good to go.   [thumbsup]
tankerbutt
You guys are good!!   Thanks a lot, i really appreciate it
