April 29, 2024, 07:08:13 AM *
Author Topic: Altenative ECU  (Read 6982 times)
greenmonster
« on: October 12, 2008, 06:39:11 AM »
MyECU: http://www.cajinnovations.com/MyECU/index.htm
Also fits other Ducs w P7, P8, 1.5 & 1.6 WM ECU like M900ie 00-01,
851/888, some 916, most 748, ST2 & 4, 750 & 900SSie.
I know from FHE it works in 907, ST4, 888.
Best is to get a used chassi w the big AMP 36-pin connector. You switch PCB, looks like this:
You get the software in a mail, looks like this (older version):
Could also be opened w f e Wordpad, here`s a part of it:
#Temp C -30 -20 -10 0 10 20 25 30 40 50 60 70 80 90 100 110 125
OilT% +64.1 +53.1 +43.8 +35.2 +29.7 +18.8 +10.2 +9.4 +5.5 +0.0
# AirT is the barometric adjustment for air temp(based on ideal gas law)
AirT% +24.7 +19.8 +15.2 +11.0 +7.1 +3.4 +1.7 +0.0 -3.2 -6.2
# This defines the throttle breakpoints. This on top of TPS base above
THR 960 896 832 704 640 576 512 448 384 320 256 192 128 64 0
RPM 500 1100 1500 1801 2000 2302 2601 2900 3360 3654 4045 4655 5353 6157 7082 8143
SpkAdv 14 11.02 12.42 13.36 19.45 22.03 23.44 25.31 27.19 27.42 32.81 34.45 36.56 36.56 36.56 35.16 35.16
SpkAdv 13 11.02 12.42 13.36 19.45 22.50 23.67 25.55 27.42 27.89 29.06 34.45 36.56 36.56 36.56 35.16 35.16
SpkAdv 12 11.02 12.42 13.36 19.45 23.44 24.38 25.78 27.66 29.06 29.06 34.45 36.56 36.56 36.56 35.16 35.16
SpkAdv 11 11.02 12.42 13.36 19.45 23.44 24.61 26.25 28.13 30.00 30.47 34.45 36.56 36.56 36.56 35.16 35.16
SpkAdv 10 11.02 12.42 13.36 19.45 23.44 24.38 26.48 28.59 30.47 30.70 34.45 36.56 36.56 36.56 36.56 35.16
SpkAdv 09 11.02 12.42 13.36 19.45 23.44 25.31 27.42 29.06 31.64 32.81 34.45 36.56 37.27 37.50 37.50 37.50
SpkAdv 08 11.02 12.42 13.36 19.45 23.44 25.31 27.42 29.06 32.58 34.45 35.86 37.73 39.61 39.84 39.84 39.84
SpkAdv 07 11.02 11.02 13.36 19.45 23.44 25.31 28.83 29.06 32.81 34.69 36.33 39.14 40.31 41.02 41.02 41.02
SpkAdv 06 11.02 9.84 13.36 19.45 23.44 25.31 28.83 31.64 33.28 35.86 38.91 40.78 41.72 42.66 42.66 42.66
SpkAdv 05 11.02 9.61 13.36 19.45 23.44 25.31 28.83 31.64 34.22 37.73 40.78 42.42 43.59 44.06 44.06 44.06
SpkAdv 04 11.02 9.38 13.36 19.45 23.44 25.31 28.83 31.64 34.22 37.73 40.78 42.42 43.59 44.06 44.06 44.06
SpkAdv 03 11.02 9.38 13.13 19.45 24.14 25.31 28.83 31.64 34.22 37.73 40.78 42.42 43.59 44.06 44.06 44.06
SpkAdv 02 11.02 9.38 13.13 19.45 24.14 26.95 29.30 31.64 34.22 37.73 40.78 42.42 43.59 44.06 44.06 44.06
SpkAdv 01 13.13 9.38 13.13 19.45 25.08 29.30 29.77 31.64 34.22 37.73 40.78 42.42 43.59 44.06 44.06 44.06
SpkAdv 00 13.13 8.20 4.92 14.30 25.08 29.30 29.77 31.64 34.22 37.73 40.78 42.42 43.59 44.06 44.06 44.06
You could also alter all parameters in Wordpad.
You have full access to all parameters in WM + some good new ones, like possibility to connect wideband Lambdas,
set A/F targets, switch to Closed Loop Mode and tune on a Dyno or road and save the result!
Quite simple setup & communication: PC - RS232 adapter - MyECU:
Only quirk is that it uses own TPS breaks values instead of usual percent. But there is a formula to convert that.
Any old laptop will do, I got mine f free and use W98!  Cool
If you buy MyECU as a DIY kit you`ll end up w a cost of something like 300-370 US$.
Been mapping carefully w original map as starting point, 30-40 maps later I`m quite happy w the result:
Measured at rear wheel, SAE.
Engine mods: MyECU P8, polished inlets & ports, 900SSie cams, HC pistons, optimised squish, open airbox, F1 mufflers.
Good driveability, even 2-3500 RPM 3-4-5 gear, and good punch at 6-8000.
Not so bad f an only assDyno mapped old 907! Grin
Dyno finetuning will follow.
M900 -97
MTS 1100s  -07
CDawg
S4RS
« Reply #1 on: October 13, 2008, 05:23:24 AM »
Nice looking graphs!
greenmonster
« Reply #2 on: October 13, 2008, 06:26:59 AM »
Thx!
Pretty proud over the assDyno A/F chart.
M900 -97
MTS 1100s  -07
Langanobob
« Reply #3 on: October 26, 2008, 05:25:34 AM »
greenmonster,
Thanks for posting this.  I think our friends at Ignitech also make a similar replacement ECU for fuel injected bikes.  Just wondering if you know much about it?
greenmonster
« Reply #4 on: October 29, 2008, 08:37:59 AM »
You`re welcome.
Checked them alittle, dunno more than the ignijet04 has a preset for 996 which I guess works f S4R/Rs.
It`s a bit primitive on the ignition mapping side, just the same parameters as onTCI-P4!
OK price and experience w the TCI-P4 is still good after 2 years of working flawlessly so I might bought one
if it was possible f my 907.
All in all, quite happy w MyECU for now, hope someone will try it on a Monster 00-01.
Posted this to show the possibility for that. Maybe too hard w the Immobilizer/instrument panel issue though.
Do you have a TCI-P4?
EDIT: Just checked ignijet07, much better w 999 & 996 possibility and fully programmable ignition + all you can think of!
« Last Edit: October 30, 2008, 06:44:36 AM by greenmonster » Logged
M900 -97
MTS 1100s  -07
Langanobob
« Reply #5 on: October 31, 2008, 05:47:51 PM »
Quote
Yes, I bought one to use on my 1986 Cagiva Elefant with a 650 Ducati Pantah motor. But...it's languishing on the bench along with half a dozen other started-but-not-finished projects.
