Why is oil leaking from my oil filter?
Started by Trenchdigger, October 17, 2008, 09:23:07 AM
Jobu
Ducati actually has a torque spec for the oil filter, 16nm. or 11.8 ft lbs.
Jobu
Quote from: howie on October 17, 2008, 07:36:17 PM
I think Ducati pulls some these touque specs out of a hat (their ass).
Quote from: Jobu on October 17, 2008, 07:49:18 PM
Does that make them ass-hats?
Of course not. They're from Italy, not Massachusetts.  [roll]
Trenchdigger
I am a RIDER!
http://www.nedr.org/
Trenchdigger
UPDATE!!!
Using the Strap-Wrench to torque the filter down a bit more did the trick.  NO MORE LEAK!!!
I'll be buying a proper torque wrench and a filter "socket" to get the filter on just right from now on.
Thanks for listening!!!  :)
I am a RIDER!
Rameses
Quote from: Trenchdigger on October 20, 2008, 04:27:34 PM
UPDATE!!!
Just go with the K&N oil filter and you won't have to worry about a special socket.
They have a regular hex-head built on the bottom of the filter.
SP3
#23
Quote from: Capo on October 17, 2008, 09:38:08 AM
Check the flange of your filter to make sure the threaded inner boss is not bottoming out on the threaded nipple preventing the seal ring from compressing
+32.432
I have had two filters with this problem over the years.
1991 851 SP3
1966 250 Monza
1999 Monster 900 City
cgos4r
Can you please confirm this spec? I tried 8 ft/lbs, but still have seepage.
2006 S4R LE 1/1502005 XFire SRT6 1/2016
DucHead
Quote from: Rameses on October 21, 2008, 12:41:10 AM
+1  I use K&N oil filters on all my vehicles primarily for this reason.  I dislike strap wrenches.  [bang]
cgos4r
Quote from: ducpainter on December 30, 2008, 07:31:02 PM
http://ducatimonsterforum.org/index.php?topic=373.msg39052#msg39052
Thanks, someone had mentioned 11.5 ft/lbs; however, the specs listed on that other thread say 10 - 12 Nm. So, max ft/lbs would be 8.85.
