January 08, 2025, 09:05:15 AM
Please Help
TPO Beast vs. Open Air Box w/ K&N
Topic: TPO Beast vs. Open Air Box w/ K&N (Read 11132 times)
scott_araujo
Re: TPO Beast vs. Open Air Box w/ K&N
Reply #30 on:
October 27, 2008, 06:04:54 AM »
I think the TPO are better than the stock stacks in the box. Correct me if I'm wrong, but the lip on the stock ones is sharp, the lip on the TPOs is rolled over. That little roll over at the edge usually makes a big difference in flow rates.
Scott
Reply #31 on:
October 27, 2008, 07:49:19 AM »
Quote from: scott_araujo on October 27, 2008, 06:04:54 AM
Scott
nah they are flared too.
Quote from: Mother on October 26, 2008, 09:31:55 PM
Damn
and here I just went through the pain of talking myself out of the TPO kit
youz guyz are killin me
Obama is pro choice
McCain is ProPods
your choice. =p
Last Edit: October 27, 2008, 07:51:29 AM by He Man
scott_araujo
Reply #32 on:
October 27, 2008, 10:04:18 PM »
They are both flared and greatly improve flow. It's the very edge that's different and that I'm referring to.
Nice and rounded like this:
http://www.vogelmanufacturing.com/images/horn.jpg
generally flows better than a sharper edge like this:
http://performanceparts.com/performance_parts_images/mr_gasket_46.jpg
I think the ones in the stock air box do NOT have rounded edges though I could be wrong, I haven't looked in there since the beginning of the season.
Scott
Norm
hurricanemotorcycles.com
Reply #33 on:
October 28, 2008, 06:03:57 AM »
I'm far from an expert on the subject, but why would the shape of the outer lip matter?
scott_araujo
Reply #34 on:
October 28, 2008, 07:33:32 AM »
It's all about turbulence and smooth air flow. That sharper edge creates more turbulence and lower air flow. Less oxygen for the engine. It's a really small thing that makes a measurable difference on a dyno.
Scott
Bill in OKC
S4Rs
Reply #35 on:
October 28, 2008, 08:19:05 AM »
Quote from: EEL on October 27, 2008, 05:32:17 AM
Also, a lot of people who comment on PODS install them directly onto the intakes.
That looks like where I'm heading. I waited for TPO to make a 4-valve beast, but they didn't make it POD friendly. I'll lose some power along with the velocity stacks but I'll just have to live with it
'07 S4Rs '02 RSVR '75 GT550 '13 FXSB '74 H1E '71 CB750
Reply #36 on:
October 28, 2008, 10:15:20 AM »
Quote from: scott_araujo on October 28, 2008, 07:33:32 AM
Scott
How much of a measureable difference?
supertjeduc
Reply #37 on:
October 28, 2008, 01:00:34 PM »
I die dyno my m900sie with airbox/k&n/half open lid
And with the Pods on the stock stacks
Difference was 0,5hp (airbox won)
Norm
Reply #38 on:
October 28, 2008, 01:05:49 PM »
OK, I get it now. I thought you meant using the velocity stacks with pods clamped over them. I'm trying some ram air experiments with 41FCRs but won't know much 'til spring. BTW, nice machining.
EEL
Reply #39 on:
October 28, 2008, 11:15:32 PM »
Actually Norm,
TPO velocity stacks ARE slipped inside the pods..
Norm
Reply #40 on:
October 29, 2008, 05:38:36 AM »
Then, assuming the filter touches the edge of the velocity stack, would the edge shape make a difference?
EEL
Reply #41 on:
October 29, 2008, 07:50:41 AM »
Couple of comments:
1) Norm: I think you make a very good point.
2) I think this conversation is getting too theoritical. The fact is that most of these comments about about air flow are related to a stable/fixed environment, reality changes these results significantly (i'll explain this in a second). The important goal is to ensure that the stacks themselves are long enough to establish a laminar flow path based on the maximum air intake capacity that the bike is utilizes. We have to realize that TPO pods are in reality cantilevered off the intake ports. So they will vibrate a tad due to many factors such as engine vibration, bumps, etc. This will (and DOES) inherently impact air flow. This effect is more evident when I go over cluster of bumps at high speed.
THAT is the major drawback of pods and the TPO setup. For some reason, no one ever talks about it. Proper bracing could solve this problem but I dont think anyone has attemped to secure them in this fashion.
3) In regards to the HP. I agree that pods are probably a tad less than efficient and most likely down on peak HP. But I own a MONSTER,if i cared about peak horsepower, i would have bought a 4 valve bike. Personal opinion here: But I feel that Pods work much better in the mid and low rpm range. I wouldn't be surprised if the dyno shows this. Whoever mentioned that they have a dyno test, can you post the results for comparison?
Last Edit: October 29, 2008, 08:20:51 AM by EEL
