Favorite bikes of all time.
Started by Scottish, May 10, 2008, 08:07:38 PM
Scottish
#15
OHhhhhhhhH!!!!!!! Ultra-burn!!!!! I'm gonna need a little ointment for that!!!  [laugh] OK back on topic...
anyone remember this?? $60K oval pistons, one of the first street bikes with the SSS, and underseat exhaust. It was way trick when released, back in the early '90's, around the same time as the Monster hit the scene.
Randimus Maximus
Ducatiloo
750 SS 01    800 S2R 05  Aprilia RST 1000 futura
Smitch
Quote from: Ducatiloo on May 19, 2008, 02:27:59 PM
Wait She?
I'm not touching that one...but that does look like a lady holding squid (or octopus, I guess).
Too true on the Matrix edition.  Dang I want one of those...
Ducatiloo
Quote from: Ducati900sp on May 19, 2008, 08:07:32 PM
/Users/walterrandolph/Pictures/Ducati poster/vegas10.jpg
If we don't have access to your pc, we can't see your pic.
Smitch
Quote from: WannaDucBad on May 19, 2008, 02:28:17 PM
Fo' real, that would look tight with an extended swingarm, maybe like 2 extra feet.  Oh hells yeah.
No but seriously, long tail on that bike.  What model is it?  Pretty sweet.
Ducati900sp
DUCATI-CAMPIONE DEL MONDO SUPERBIKE
Ducatiloo
#22
Tesi3d only time will tell
Scottish
Quote from: Smitch on May 20, 2008, 06:54:57 PM
Honda NR750. It was a limited edition hand built bike in the early '90's
Here's a spec sheet, and write up:
Make Model
Honda NR 750 NR40
Year
1992
Engine
Liquid cooled, four stroke, 90°V-four oval cylinder, DOHC, 8 valve per cylinder.
Capacity
747.7
Bore x Stroke 101.2 x 50.6 x 42 mm
Compression Ratio 11.7:1
Induction
Electronic fuel injection 8x 30mm chokes, 2 injectors per cylinder
Ignition  /  Starting
Computer-controlled digital   /  electric
Max Power
125 hp 92 KW @ 14000 rpm (rear tyre 115.8 hp @14500 rpm)
Max Torque
47.9 hp 6.6 kg-m @ 11000 rpm
Transmission  /  Drive
6 Speed  /  chain
Gear Ratio 1st 2.666 (40/15)  /  2nd 2.125 (34/16)  /  3rd 1.777 (32/18)  /  4th 1.545 (34/22)  /  5th 1.381 (29/21)  /  6th 1.381 (29/21)
Frame Triple-square section twin-tube
Front Suspension
45mm Showa inverted telescopic forks, preload, compression and rebound damping adjustment. 120mm wheel travel
Rear Suspension
Pro-link arm Showa monoshock, preload, compression and rebound damping adjustment. 120mm wheel travel
Front Brakes
2x 310mm disc 4 piston calipers
Rear Brakes
Single 220mm disc 2 piston caliper
Front Tyre
130/70 ZR16
Rear Tyre
180/55 ZR17
Seat Hieght 785 mm
Dry-Weight
220 kg
Fuel Capacity
17 Litres
Consumption  average
12.6 km/lit
Braking 60 - 0 / 100 - 0
12.9 m / 35.9 m
Standing ¼ Mile
11.4 sec / 197.3 km/h
Top Speed
257.3 km/h
The Honda NR750 is possibly the ultimate superbike. It may not be the fastest, and it may not be the best, but it is arguably the best looking,  undoubtedly the most technologically advanced, and unquestionably the most expensive.  What makes the NR750 so special is the amazing high-technology it boasts. It is Honda's way of proving how clever they are, corporate muscle-flexing by a company who wanted to prove that they build quality as well as quantity. Space-age engineering is packed into every cranny of the NR, making it a unique and fascinating machine. But at £36,500 each (and Honda only built 700 of them) you'd expect it to be rare. When it costs five times more than the same company's flag-ship sportsbike, the NR750 would have to be something a bit out of the ordinary.
What's most special about the NR750 is its engine. The NR is clever in many respects, but the it is the engine that sets it apart from any other motorcycle. This liquid-cooled V4 motor uses oval pistons, no less than eight valves per cylinder and features a highly sophisticated fuel-injection system. A 32-valve fuel-injected V4 750 is an astonishing feat of engineering, and one which allows Honda to produce a lot of power from a relatively small package.  Each of the two cylinder banks has double overhead cams. Each piston (they are actually oblong shaped, but with rounded-off corners, rather than purely oval) has two con-rods, two spark-plugs and eight valves. Why all this high-technology? Engines using lots of valves, all opening and closing quickly, can rev higher than ones with fewer valves. With a rev limit of 15,000rpm and an advanced fuel-injection system, the NR750 produces an impressive 125bhp (although pre-production prototypes were capable of 140bhp and the racing bike on which the NR is based was making more than 160bhp).   But there's more to the NR750 than oval-piston technology. The aluminium-alloy chassis is a work of art, combining strength and rigidity with lightness, and the NR's suspension is the best money can buy. At the front the NR features massive inverted Showa i forks and at the back it uses Honda's fiendishly [clever single-sided swingarm developed for fast wheel changes in endurance racing.  But most breath-taking of all is the body-work, i an impressive mixture of carbon-fibre and fibreglass that costs more than the total price of any other mass-production motorcycle. Even the NR's windscreen is titanium-coated and costs more than most people earn in a month.
The styling of the bodywork is sleek and seductive, the lines beautiful and the finish higher quality than anything seen before from a 'mass-produced' motorcycle.  As far as performance goes, the NR is good rather than exceptional. There are plenty of other motorbikes that will accelerate faster and reach a higher top speed, but the NR750 is one of the best handling bikes on the road, capable of going from 0-60mph in under four seconds and reaching a top speed of 160mph.  The NR750 is so expensive and exclusive that most people will never see one, let alone come across one on a public road. Which is a shame because it is undoubtedly the best looking and most exciting production motorcycle ever made.
Source of review: Super Bikes  by Mac McDiarmid
Randimus Maximus
Quote from: Ducatiloo on May 20, 2008, 08:34:07 PM
there are some really cool bits on that bike.
I'm not really sold on the front suspension, but I've not ridden it either.
Ducatiloo
Like I said only time will tell,  It's gotten great reviews, and may be setting a trend in a few years of use, or it just may be a gimic to sell bikes.
Either way no one is going to mistake that for a Harley.
Randimus Maximus
The Motoczysz is a good looking bike as well!
Scottish
Quote from: Randimus Maximus on May 21, 2008, 08:45:54 AM
hells yes it is, looks sooper-dooper fast!
Ducati900sp
Check out the stats on this bad boy!
GENERAL INFORMATION
Manufacturer       NCR
Model Year       2008
Model       Millona One Shot
MSRP        Request a Quote
ENGINE
Engine       Ducati 1100 NCR
Gross Horsepower       116 hp @ 8,450 rpm
Torque       10.8 kgm @ 6,700 rpm
Clutch       NCR Corse by Aptc anti-hopping system
Exhaust       Full system developed by NCR and produced in titanium by Zard
DIMENSIONS
Weight       267 lbs. (121 kg)
Frame       Tubular trellis in chromium molybdenum (projected and developed by NCR)
Wheelbase       55.12 in. (1,400 mm)
Fuel Capacity       3.9 gal. (15 l)
DRIVETRAIN
Transmission       6-speed
Suspension       Front: Öhlins 43 mm upside-down fork with TiN surface treatment, adjustable off-set, for radial calipers with NCR CORSE aluminum bottom bracket from billet, seted up by NCR Corse
Rear: Progressive linkage w/ fully adj. Öhlins monoshock w/ adj. length, seted by NCR Corse
BRAKES/WHEELS/TIRES
Brakes       Front: 2 x 300 mm braking WAVE discs, 4-piston 2-pad Brembo SBK radial caliper from billet
Rear: 200 mm braking WAVE disc, 2-piston Brembo caliper from billet
Tires       Front: Metzeler Racetec Slick K0, 120/70 R 17
Rear: Metzeler Racetec Slick K0, 190/55 R 17
Wheel Set: BST for NCR carbon fiber wheels
Rake       23.5-24.5°
Colors       One Shot 07 paint job
Smitch
