February 12, 2025, 02:20:27 AM *
Pages: 1 2 [3] 4 5 ... 9   Go Down
Author Topic: Two-up Group Ride 12/6!!! (Weather permitting)  (Read 30197 times)
Desmostro
alis volat propriis
« Reply #30 on: November 22, 2008, 01:33:04 PM »
 waytogo want to.   Many variables up in the air. When we get closer to Dec. I'll know more.
My suspension is tres soft... I wonder if I should mess with that for 2 up, otherwise I might be riding one wheel up  Tongue
mostrobelle
« Reply #31 on: November 22, 2008, 02:12:42 PM »
I was going to wait on this, but I'll put it up here now to get a dialogue going about the best way to ride two-up.
OK, so I'm not a suspension expert, but my understanding is that you need to increase your pre-load.  On my bike that's a real pain.  It involves a large screwdriver and a mallet.  As Enzo's brother would say, it's probably a four-goddammit job for me.  (The number of times I'll say that while I'm trying to do it. Grin)  So when I take m'boy on back I usually get lazy and simply add about three clicks to the Ohlins that I have on the rear.  I think the Ohlins only controls the rebound--someone correct me on that if I'm wrong.  Anyhoosiers, the end result is that I get a bike that's a lot stiffer and it works for both me and my guy.  Trust me, riding around on a mushy back end can make things really interesting.  And I know quite a bit about mushy back ends both on and off the bike.   Grin  The point is, if it works for me and someone who's 163% heavier than me, chances are that it might work for you.  If anyone is planning on doing a "sporting pace" I'd suggest that you make the "proper" adjustments and not half-ass it like moi.
94,500 miles...05/22/15
CharliesAngel
2003 M620 (sold), 2001 900SS
« Reply #32 on: November 23, 2008, 09:05:09 AM »
Sure, but who's "the Groupie"?  The English lass from Zeitgeist?
Alas, it is not the lass from Zeitgeist - although she showed a definite interest in riding cupcake on Dec. 6th.  The Groupie = Frances  Grin
Tu deviens responsable pour toujours de ce que tu as apprivoise. - Fox to le Petit Prince
desmoquattro
« Reply #33 on: November 23, 2008, 05:15:31 PM »
...nothing wrong with that Evil
My Vices
'09 KTM 690 SMC (Thumpy)
'05 MS4R, blue
Michael Moore
Testa di cazzo
WebGeeK
« Reply #34 on: November 23, 2008, 05:37:04 PM »
Ah, OK. I'm happy to give Frances a ride. Monster or Vespa.
La nuova moto e il vecchio motociclista :: 2000 Monster 900 (il vecchio) :: 2008 Vespa GTS (doppio) :: 2010 Streetfighter S ("il PastaBusa")
CharliesAngel
« Reply #35 on: November 23, 2008, 06:41:11 PM »
Hi MM! She's ridden on a Greyduc's Monster as well as Petemg's S2R so she's quite familiar with sitting on a Monster if that will be your ride of choice  Grin
Jammen
« Reply #36 on: November 24, 2008, 07:17:43 AM »
To add to this,
It's also doubly important to check the basics tire pressure, chain tension, brake function, etc etc.
Having a tire a couple pounds under ideal, or a sloppy chain becomes way more apparent with an extra body on the bike.   waytogo
The world awaits.
CharliesAngel
« Reply #37 on: November 24, 2008, 08:14:36 AM »
Hey 'belle,
I have another girlfriend who might be up for riding cupcake (she has to double check her schedule - I just wanted to give you a heads up) if there is a passenger spot available.  I'll post up as soon as I hear from her.  Also, I'll be riding cupcake on my SS and Jammen will be riding it.  I think that Somebastid offered a seat to BikerGoddess.  Thanks!  waytogo
mostrobelle
« Reply #38 on: November 24, 2008, 09:05:04 AM »
Updates made to first page.
mostrobelle
« Reply #39 on: November 25, 2008, 11:13:22 AM »
Can someone vouch for the "normal loop" being in decent shape for the upcoming ride?  MM posted up that Tam was nasty...just wondering if we should change routes.
Btw, I'm thinking of a meet time at Tam 'Bux at 9:30 with a departure of 10:00 or so.  I have friends coming on this ride that have no interest in the usual pre-dawn meet times we generally do.   cheeky  It will give the roads a chance to warm up, too.  We could probably stop at Nicasio Cheese place or the Mexican joint for lunch if folks are interested before heading our separate ways.
desmoquattro
« Reply #40 on: November 25, 2008, 11:53:39 AM »
MM mentioned that Panoramic was in bad shape, but we could easily avoid that by hitting the coast. Panoramic isn't that fun 2-up anyway...
My Vices
'05 MS4R, blue
Michael Moore
Testa di cazzo
WebGeeK
« Reply #41 on: November 25, 2008, 12:13:09 PM »
Agreed. The coast is the way to go.
tigre
Ouch!
« Reply #42 on: November 25, 2008, 01:30:13 PM »
MB--
The clicker that is easily accessible (on your reservoir) is your compression damping.  Yes, adding a few clicks to that can help a bit when carrying extra weight.  I wouldn't worry about muddling around with rebound damping.  If you want to add preload, on your shock, you de-couple the two lock nuts (loosen the top one) then torque down the lower one, then tighten the top one back down to lock things in place.  I don't have any rough rules of thumb, but I'd guess ~2 turns would make a positive difference.
BTW: I'm in with a cupcake, and I'll sweep.  I will be going slow and want no one behind me to see how slowly I'll be going.  Smiley
Tigre
'12 1199RS Tigre 6
'12 1198RS Tigre 7
'00 M944S Tigre 1
AFM #5 - Open Twins and more
mostrobelle
« Reply #43 on: November 25, 2008, 02:14:44 PM »
Muchas gracias for technical info and offer to sweep.  First post update with, well, a lot of stuff.  Read it, peoples.   Grin
CharliesAngel
« Reply #44 on: November 25, 2008, 02:26:27 PM »
Mi dispiace!!! The Groupie has just informed me that she won't be able to go on the Two-Up Group Ride!   Cry  She wanted to give as much advance notice as possible - very sorry for any inconvenience this might have caused MM!   Undecided
Pages: 1 2 [3] 4 5 ... 9   Go Up
