She's pushin' 50........
Started by Popeye the Sailor, May 11, 2008, 07:36:52 PM
TTIWWOP you make the beast with two backsin' tease.....
Quote from: Duck-Stew on December 01, 2009, 02:10:27 PM
It's dark under there! And I'm pretty sure I saw a spider crawl under and not come out-I can't take that risk.
How's about a video of me chasing down a boxster in the twisties?   [evil]
Quote from: ducpainter on December 01, 2009, 02:00:30 PM
You actually found a painter?   [laugh] [laugh] [laugh] [laugh] [laugh] [laugh]
Reb Baron knows a lot of suckers, apparently.
Quote from: MrIncredible on December 01, 2009, 02:55:01 PM
cash flow can be motivating
Name the part, and the issue.
Cast iron distributor gear for a small block Ford which is incompatible with a roller camshaft in the long term.  Bronze gears solve the problem of hunting and wandering ignition timing.
Quote from: Duck-Stew on December 01, 2009, 03:10:40 PM
Yes on the issue-used stainless gears to fix.
Stella
Quote from: Stella on December 01, 2009, 04:51:43 PM
Can I put it on lay-away?   ;)
The worn out cast-iron distributor gear?!?  Early Christmas present for someone extra-special maybe?!?   [laugh]
Stainless?!?  REALLY?  When I was a-hot-roddin'...the ticket was a bronze gear.  Are you sure the stainless one won't gall?
Stella
Quote from: Duck-Stew on December 01, 2009, 04:53:21 PM
Seriously?    ;)
Randimus Maximus
No-it goes on my "wall of stupid" next to the breaker bar with the thirty degree bend in the handle and a melted voltage regulator.
It'll be fine  ;)
cduarte
Needs a 9" with posi and 3.73s  [evil]
cduarte
#59
9" is a waste of time with a small block ford, the 8" is more than strong enough and is the same design with the rear bearing support on the pinion gear, with the added benefit of being much lighter. Get an 8" posi with 3.50s or 3.80s...
