S4RS Quat D Ex-box owners
Started by SikDuc, December 04, 2008, 07:36:07 PM
moto
#30
Although you don't need to make changes to the fueling, there are some options that can improve the "rideability" for as little as $80 all the way up to $1200.
Here is a quick summary:
FATDUC Manipulator :Works on closed loop systems with a single O2 sensor like the 695, S2R1000, S4R and S4RS. This modifies the O2 sensor signal to the ECU to smooth out throttle response and eliminate popping. You will have to play with it a little but it solves most minor issues when installing a new exhaust. It is not designed to make changes in the mapping.
Power Commander (PC3):
Modifies the signal to the ECU so you can creste your own maps. Available for the 620ie, M1000, M900, [Monster S4 01-06, S4R -06, ST3/4, [S2R 800[ .
Rapid Bike (RB3):
Also a piggyback system like the PC3, but it allows for a ignition mods and has an O2 sensor option so you can retain the closed loop system on some bikes. These are available for bikes such as RAPID BIKE 3: S2R1000, [RAPID BIKE 3: S4R 03-06, RAPID BIKE 3: S4R 07-08 .
Ducati ECU remap kit : this basically installs a Ducati Performance type map on your existing ECU. It is reversible. Available for Monster S4R /S2R/1000. Maps will soon be available for the 696, 1100 and other new bikes.
NEMESIS-2 Type 2 ECU: HM, M695, S4RS, SC: This is a completely new programable ECU with a host of features designed for high performance.
You can download a base map or create your own map.
Ducati Performance ECU: This replaces the ECU with a remapped one that works for most exhaust systems. It is not programable.
-M
www.motowheels.com
96 M944
98 900SS FE
01 996R
02 MV Agusta F4 750
05 999R
06 SC1000
07 1098
08 M696
