Alternator Cover Puller Tool needed
Started by Vino900, December 14, 2008, 06:25:36 AM
tcspeedfreak
if i recall correcly its a common size socket for spindle ends on most front wheel drive cars so it should be able to be found
just another fool playing with boats and bikes
Desmo Elmer
QuoteInsert Quote
I thought the guy at Welle said it was a common something on a car :P
I try to stay away from working on those contraptions.  [bang]
30mm = 1.181"
1.188" = 1-3/16"  so a 1-3/16" socket would also work, only .007 too big which is probably closer than the mfg. tolerance on a socket that big...
Ross
'04 M800 (R.I.P. Whitey)
'06 S2r 1000 R.I.P
'07 S2r 1000 rubber still down
'05 GasGas MC 250 watch it or she'll loop on ya
'91 Husky 610wxe "paintshaker"
Vino900
I picked up a 30mm socket at NAPA.  Thanks for the penny tip.  I will use it this weekend if I can find the time between kids sports and wife's home projects.
[wine]
1999 900 SS i.e Track modified (right side)
Vino900
Desmoelmer thanks for the penny tip.  It worked great while torquing to 140 Ft-lb.
I had to pick up a set of impact sockets as the new lighter flywheel used 2 separate nuts (36 &38mm) instead of the original split 30mm.
I will report back on feel of light flywheel after I get the bike out in the spring.
[wine]
fasterblkduc
I'm so behind on what I need to get done on the race monster [bang]
Atomic Racing
Zalusky Advanced Riding School Lead instructor
2010 partners:
Komodo Gear, Motorex, Studio299, Moto Primo, Caztek, Chickenhawk
Desmo Elmer
QuoteDesmoelmer thanks for the penny tip.
Glad it worked for you.
Ross
'06 S2r 1000 R.I.P
