February 05, 2025, 07:57:36 AM *
Pages: 1 2 3 [4] 5   Go Down
Author Topic: Lowered headlight bracket "kit"  (Read 36434 times)
For $50 you can touch my
« Reply #45 on: January 02, 2009, 12:22:14 AM »
NOTE: If you are using Ti fasteners.  ALWAYS ALWAYS ALWAYS use Ti prep, or antiseize (nickle based/silver stuff) otherwise you risk galling (actually you always risk that, when dissimilar metals are fastened together).
Are you sure it's dissimilar metals that risk galling? I'm pretty sure it's the other way around.....
« Reply #46 on: January 02, 2009, 01:01:07 AM »
Hey Chchadder, so how did you get this pin out?  Will a pair of pliers do the trick?
And/or HeMan, since you weren't able to remove yours, can you elaborate a little on how you dealt with the situation?
TIA,
b.
We ended up just knocking it off by accident. the next pin was forcefully removed with little effort.
If you look at the pics, youll see how I ended up doing it.
TAftonomos
is without a monster :(
« Reply #47 on: January 22, 2009, 07:47:13 AM »
Bumpage, I've got 2 "cores" now that are modified and ready to go Smiley  waytogo
OverCaffeinated
« Reply #48 on: January 22, 2009, 08:37:49 AM »
A quick question if y'all don't mind. If I'm planning on ditching the whole headlight and going with something fork mounted, do I need a headlight bracket at all? Will I be able to mount my gauges below the triple solid enough, without the headlight bracket holding them there that they don't snap off if hit a bump?
TAftonomos
« Reply #49 on: January 22, 2009, 08:45:30 AM »
Maybe, but I'd count on drilling the tripple for a larger mounting bolt.
It's only a M5 as OEM, and I wouldn't want to hang the gauges off of that.
OverCaffeinated
« Reply #50 on: January 22, 2009, 09:00:16 AM »
I agree about it being too small of a bolt. I'm pretty set on doin it this way. I'm sure I can figure something out.
Thanks
b.
« Reply #51 on: January 22, 2009, 09:15:39 AM »
I forgot to post pics of my finished product!  Thanks again to Theo for a great product...the welding was perfect.   waytogo
2005 M620 | so*cal | terapia.
OverCaffeinated
« Reply #52 on: January 22, 2009, 09:25:33 AM »
Looks really clean!
Everything looks tight and compact.  waytogo
DucSteve
Hey Yo
« Reply #53 on: January 22, 2009, 11:55:46 AM »
How much work is required to install your new bracket? Basically just bolt on or any other work/parts required? I've been interested in lowering my headlight for a while
Gimpy
Not quite a
« Reply #54 on: January 22, 2009, 12:25:55 PM »
It's not galling per se, but two dissimilar metal are subject to galvanic corrosion.  Which is fancy talk for "won't get the #$%@ out of my engine block"
TAftonomos
« Reply #55 on: January 22, 2009, 12:42:01 PM »
I posted pics in the thread, pretty simple Smiley  waytogo
DucSteve
Hey Yo
« Reply #56 on: January 22, 2009, 08:59:40 PM »
Well I'm def interested in lowering my headlight on my s2r1000... I want clipons bad  laughingdp
DarkStaR
« Reply #57 on: January 22, 2009, 09:06:50 PM »
Nice Clutch Lever!  laughingdp laughingdp laughingdp
b.
« Reply #58 on: January 22, 2009, 10:31:03 PM »
You bastard.  Haha...and to think I even felt bad for not publicly thanking you for helping me wrench!
« Reply #59 on: February 17, 2009, 08:54:29 PM »
Not as nice as my clutch lever.  laughingdp
But its going away when the ASV Shorty gets here.  Grin
Pages: 1 2 3 [4] 5   Go Up
