12-16-08.... The Dark Ages begin
Started by Grampa, December 16, 2008, 07:40:20 PM
you should find some of that DoD black paint they use for the Stealth fighters.
something like 90% non reflective and has some kind of teflon/whoosatwatsis that makes the surface slippery.
Rob Hilding
Quote from: ducatizzzz on December 18, 2008, 11:07:03 AM
And since it's DoD paint - I'll bet it is only 11ty billion $$ a quart (or less) ;D
Quote from: bozcorob on December 18, 2008, 11:09:17 AM
i saw some on Fleabay for $200 for a quart.  I am pretty sure it was for real.  It is not classified or anything (anymore at least).
Its commonly called iron ball paint, it has tiny iron molecules in it which confuse radar.
Rob Hilding
Don't they also have a paint that cuts way down on the radar "reflection"
Somebody supposed painted a Porsche (930 Turbo) with it in the late 70's - It was a light gray color IIRC
AFAIK, most of the 'radar' is now laser, so not much love from the stealth paint.  [bang]
Quote from: Speeddog on December 18, 2008, 12:31:07 PM
depends on your jurisdiction.  around here only the motorcycle cops have LIDAR, all the cars have XK/K radar with RDD.
but a non reflective paint could cut down on the LIDAR reflection.  or even diffuse it entirely, but someone smarter should speak to that.
TAftonomos
Just that pesky headlight reflector will make sure the laser/radar/lidar/trunk monkey still sees you.
Am I the only one that watches Mythbusters?
You can't beat radar / lidar / foobar / whodar with just fancy / flat black paint (or with chaff, aluminum hubcaps, fancy paint, etc. etc)
On the flip side: studies show cops ticket red vehicles more than any other color.
Also studies show having boobies helps avoid tickets too.
So BP, the paint's awesome. Just get a set of implants and you're all set  [thumbsup]
Quote from: Drunken Monkey on December 18, 2008, 01:23:06 PM
i am inclined to believe that, but i would like to see them use the iron ball paint from the stealth planes..
Quote
BP with jugs.  Now I must go barf.
teasers
I'll button her up on Saturday
Kopfjäger
