Machining a stock flywheel and gears
Started by Monsterlover, December 18, 2008, 07:38:36 AM
Capo
Capo de tuti capi
2001cromo
Quote from: TAftonomos on January 04, 2009, 11:02:14 AM
Where would one find a stock aluminum clutch hub?   I know veetwo sells a billet one for 3-400.
Did ML lighten the clutch hub?
Could you be meaning the clutch basket?
Fixed that to say "basket" as that's what I meant. Doh! thanks for the catch.
I coulda sworn all the hubs were aluminum and the newer SBK's like 749/999 had a lighter aluminum hub. I've heard of the V2, but never seen one in person to compare.
like a zombie, i resurrect this thread.
you wouldn't happen to want to lighten mine would you? i'm tearing an engine apart and have lightweight/straight cut primaries, and was interested in lightening things up on the alternator side... of course, i'd pay in money and your bev of choice, with goodwill moonpies thrown in.
Me?
I could probably do it.
I just kept cutting mine until it looked good. I could have gotten more off it but access to the lathe ran short.
I could also punch holes in the clutch basket and primary gear...
already got the primary taken care of, going to use a slipper on the clutch, so it'll come with basket. (the one i'm getting does - 48T).
but the sprag gear (i believe that's the one riding behind the flywheel - that's the one I want done.
thoughts?
Sprag gear doesn't spin when the engine is running, so only benefit is the weight removed.
I'm thinking of the correct one, right - the one right behind ze Flywheel?
I forgot it was only for starting the bike. As I play in the garage with my mostly disassembled motor, I see that.
Well, weight savings from a big ass gear is weight savings. At this juncture, I suppose my deciding factor to have it machined is cost.
can you machine more holes in the timing gear that's on that side?
I can put holes in pretty much anything.
Like pistons for example ;D
I put holes in my starter sprag, primary and clutch basket.
I turned the flywheel and in hindsight I feel I could have punched some holes in that thing to lighten it up more.
There's a few pics posted around here somewhere.
i spied the pics at the beginning of the thread. i'm just disassembling this here 900ie motor and looking at making it fancy when it goes back together.
