February 08, 2025, 09:09:58 AM *
Pages: 1 2 [3]   Go Down
Author Topic: New S2R 1000 Owner + Advice Seek  (Read 4523 times)
loony888
"I WAS GOING HOW FAST, OFFICER?"
« Reply #30 on: December 27, 2008, 02:47:47 AM »
Hi, am I missing something?
Was there a gearing change too?
*80kmph in 6th gear = 3500rpm
*80kmph in 6th gear = 3000rpm
Cheers
Madalf.
that was going to be my question too!
wtf?Huh?
paul.
                                              93 888 RS
                                              09 1098R BAYLISS
                                              07 Husqvarna TE 450
                                              01 S4         93 900M
                                              96 748SP
748s
« Reply #31 on: December 27, 2008, 03:15:25 AM »
Cheers
Madalf.
No gearing change.
If someone could explain why the lower RPM with DP ECU I would be grateful
Same section of road, (flat) same speed, different RPM (Ran over the section several times....same result).
wtf?Huh?
paul.
WTF indeed!
Thanks 748. I think I understand, the DP ECU helps but isn't perfect.
Sooo, with the DP ECU you have more beans but less flatulence  Grin
Yeah more beans. Feels more responsive. ZARD with stock ECU feels.....not as sharp.
My major problem with the DP ECU with the full ZARD system is varying idle rpm.
It appears to have settled down to 1500-1900 range.
Too many mysteries with this S2R ECU business.
Maybe time for another bike.
brad black
« Reply #32 on: December 27, 2008, 04:00:34 AM »
your o2 censor wont work properly unless the cat is there
the sensor is upstream of the cat, so it makes no difference if the cat is there or not.
Brad The Bike Boy
http://www.bikeboy.org
Spider
Ozmonsters: degenerating nicely since 2008
I may be long, but I fold up nicely
« Reply #33 on: December 27, 2008, 05:24:35 AM »
and just think....the frickin thing was perfect from 03 till 05 in the M1000, then they use the same bloody engine in the s2r and the thing is like a science experiment!
(I've heard the 06 is the pick of the litter) !?&^%
I don't even know what a stepper motor is...but for f*ck sake it sounds like it causes a far whack of problems!
bazz20
« Reply #34 on: December 27, 2008, 04:16:20 PM »
its not on mine or the others ive worked on its in cat
Pages: 1 2 [3]   Go Up
