Yes or no on the number plate sticker?
Started by JTMOTO, January 01, 2009, 05:31:58 PM
JTMOTO
Will I have to have remapped if i remove it?
Quote from: DarkStaR on January 01, 2009, 07:24:57 PM
While you're at it, might as well lose the udder.  [evil]
Quote from: JTMOTO on January 02, 2009, 12:41:05 PM
Your bike has a Euro 2 compliant ECU and exhaust - that means it is less sensitive to exhaust mods than the Euro 3 bikes, like my '07.
Pretty much any slip ons will work (does your bike run well with the system you have on there?)
The problems often occurs when people with Euro 3 bikes (and O2 sensors) mod the exhaust without getting the DP ECU.
I'm not sure your bike can handle slip ons + udderless pipes, but it might work if you don't also add an open air box. Mind you, I'm not the expert ;)
If DP ECU is required to lose the udder, it's not worth the $$$ IMO.
Ask a specific question in a new thread here or ask your dealer. I'm sure you'll find out.
COWBOY
S.I.T. is correct from what i understand. On the 800 there would be no O2 issues by using the midpipe and losing the udder.  an open airbox with the midpipe would probably require the dp ecu or a pciii.
the full exhaust is worth it imo especially on the 800.  i took mine off when it looked like i'd have to sell the bike and the difference was not small going back to stock.  i have since put it back on.
increased hp aside the other advantage is weight saving.  the udder is heavy.
if you decided to keep it one look that I liked was the short termi pipe they came out with in 07.  it looks best imo with the udder and you will still lose some weight and clean up the back of the bike.
bike looks good.  like the Rizoma pieces you've added.  as far as the sticker, they're not my thing, but if you like it roll with it.  It's your bike.
cheers
2005 S2R -- Mods installed: DP termi full racing kit, ST4 Forks, S4R rear shock, 999 Radial Brake and Clutch MCs, 4 pot Brembo Calipers, 320mm Snowflake rotors, SBK Quick change carrier, 43T rear sproket, Tomaselli Clip Ons, Cyclecat Frame Sliders, ASV Levers, zero indicators, Supernova taillight
DucatiBastard
I think it looks good, but for me it needs some similar treatment on the tank for balance.
Maybe something that follows the lines of the side of the tank, somebody here has the sides of their tank Chromo'd,
my .02cents
Give a man a beer, and he wastes an hour.
Teach a man to brew, and he wastes a lifetime.
2006 Ducati S2R 800, 2004 Honda Dream 50R, 2001 Kawasaki W650, 1940 BSA M20
ProTeal55
Maybe if you had a cool looking number it would look better ?
Member: Half Fast Chicago
Website:
DesmoDisciple
Those rear sets look cracked. Better send them to me for testing and evaluation.
2000 Monster 900S-SOLD
1998 Supersport 900 FE -For Sale!
2000 748S - Thrillin' me daily!
ThelmaLou
Keep it  [thumbsup]
Add white rim tape  :)
Paint headlight ring white  ;)
2001 M600
Organ donation will save my fathers life! Give Life! - Be an Organ Donor!
JTMOTO
It's gone!!!  It kind of drew your eyes straight to it.  Thanks for the feedback.
DarkStaR
#25
Now the eyes go straight to the yellow spring, red filler cap, and huge udder.   :P
Monstro
Quote from: psycledelic on January 02, 2009, 05:59:33 AM
Buy another cowl and swap back and forth when you get tired of the current look you are sporting.  It's always good to keep things fresh.
I don't care for it on the dark, but it doesn't look bad.
++++++++++++1
