Shaving with a straight razor, my 2 cents.
Started by eichh, January 08, 2009, 09:05:47 AM
Xiphias
#15
I wonder how many drunks have slit their throats shaving while intoxicated??
I don't like the idea starting out on a Dirty Harry note....(Do you feel lucky, punk?)
Hi-ho-hi-ho....its off to the track I go.................
NeufUnSix
I don't trust myself with a straight razor. I cut myself too often with a "safety" razor.
My .02 - having used four blade and triple blades, I see absolutely no reason you would want to use more than two. The more blades, the more resistance you get. Four blades on a few days stubble is like dragging sandpaper over your face, constantly pulling on the skin and protesting every inch of the way. On top of that you still need to do several swipes to get it smooth and the results are identical to a standard razor. I can't believe people have been sucked in by these gimmicky things. I stick to disposable Gilettes and I am perfectly happy with them.
"Why did my tractor just blow up?"
eltristo
I am actually in the process of coverting to a DE razor.  The wife got me a badger brush and some cream for xmas, and I bought a razor and blades from ye olde internet.  It's taking a little getting used to, but I really do enjoy the process.  I'm not into the straight razor though.  Had a pro shave once at an old school barber and it left my face burning for days.  Luckily, the shave was good enough that I didn't have to shave again for 2 days.
I have the triple curse of thick hair, neck hair and thin skin. I used a straight razor for a few years, but in the end it wasn't worth it. For me at least, YMMV.
Having said that, I still stick by the badger brush and shaving mug. Way better than modern foams and gels.
slowpoke13
I've been using a DE Safety razor for a few years now. I love it. I've got 2. One is a classic adjustable "fat-boy" and the other is a newer Merkur (I think, it's been a while). I've got a couple hundred blades left from a large order and some from a sampler order I picked up through either shavemyface or badgerandblade.
I've got a few brushes. All badger. Some nicer than others. I've got a couple cups and bowls. But, haven't found one I really like yet.
Looked into a straight razor. But, I didn't feel like dealing with it. It does take a bit longer to shave every morning. I still do it in the shower as it's the hottest water and most comfortable/least messy solution. When I shave underway, it's still just a Mach 3. I tried the DE. But, it was too much stuff to lug to and from the shower/sink. And, not very practical for the use.
slowpokesan
Oldfisti
CairnsDuc
I have tried a number of shaving systems/Razors/foams/gels and I always broke out in a rash, even went and had a  well respected barber give me a shave with a straight razor, still no good.
But after much experimentation I found a high quality shaving oil and a Mach 3 razor give me the smoothest result with no rash.
I think most of it is down to the Shaving oil, this stuff has made shaving so much better and no annoying rash!
I am curious is anyone else using a shaving oil?
R2
How did honing the razor go?
I used to shave with a straight razor whenever I was home. I bought a regular straight razor, and a disposable blade straight razor to learn on. I never made the switch because I wasn't sure I could hone it properly. Kinda odd, I'll trust myself to put a straight razor edge against my face, but not to sharpen one.
If you think it's relatively easy, I might just have to order some norton stones, hone my blade and get to shaving this months old beard.
I went to an old school barber for a shave once, I think it was in Boston. It was the worst shave I've ever had. Some spots were raw and bloody while others spots still had stubble, at least he didn't slice me. I hope you guys have better experiences than I did.
I've tried quite a few different shave soaps and creams, my favorite so far is http://www.nancyboy.com/index.php?main_page=index&cPath=1_14. A hot lather machine would rule.
eichh
#23
R2 its not difficult at all here are some videos showing how to do it, if you go to this first link click on the lower video box for a demonstration the others just talk about razors.
http://www.straightrazorplace.com/srpwiki/index.php/The_World_of_Straight_Razor_Shaving_%28DVD%29
If your razor is in decent shape (no nicks) but needs fine tuning you would just need 8,000 or a 12,000 grit stone and a strop with a linen side and a leather side. Or here is a link to Lynn Abrams website hes a pro and offers a honing service thats very reasonable.
http://www.classicshaving.com/catalog/item/578215/526771.htm
Heres a link on how to strop.
http://www.youtube.com/watch?v=liKYctpdjC4&feature=related
Mojo S2R
I've always thought of getting a straight razor just never done it.  May go to a safety razor first though.
I shave my head with the Mach3 and am pleased with the results.  Tried one of those funky razors that wraps around your fingers and only ended up having to walk around with my head covered in pieces of toilet paper hidden by a beanie.
Has anyone been shaving their head with a safety razor?  How do you like it?
eltristo
Quote from: Mojo S2R on January 16, 2009, 09:46:12 AM
I have a friend who does it and describes it as "combing off (his) hair".
R2
Eichh, thanks for the links. I've got a new one, and I some old ones from my grandpa. I totally for got about sending them to Lynn Abrams for honing. Maybe I'll send one in to get a feel of how a properly sharpened razor should be, then try some myself.
