S*R swingarms are awesome
Started by Travman, January 09, 2009, 02:36:25 PM
DucHead
I love this board.
Swingarms, sarcasm, symmetry, chemistry and engineering all in one thread.  ;D
aaronb
Quote from: Capo on January 10, 2009, 09:14:23 AM
The S*R swing arm is made up of two parts welded together, one of which is cast.
it's actually seven tubes and two castings.
(at least i think the hub carrier is a casting, i would have to go look.  it may be a machined extrusion.  hmmm)
Milwaukee, WI
'07 s2r1k, '81 honda cb400t
Capo
The front is cast, the rear is an extrusion
Capo de tuti capi
Quote from: ducatizzzz on January 10, 2009, 08:17:24 AM
Yes, with "equal material and equal weights" you limit the design quite a bit.  The SxR bikes' SSS uses a fully tubular design which is stronger than a box design (same reason modern tow hitches are tube and not box).
If you had a tubular DSS, it would probably be stiffer, but the tube stuff is more expensive to work on.
Not entirely true...
For equal volume (weight) members, tubular may or may not be stiffer than a boxed frame.  If it is in bending, a box (rectangle actually) will win.  If it is in torsion, a tube will win.  If it is in compression, they are basically equal unless the member is long enough to buckle.  If it is for looks, then that is up to the beholder.
Most stressed members are actually optimal in some odd custom shape that is perfect for the application.  But, for off the shelf selection and fabrication, a lot of parts come out as tubes or boxes even though a pear/conical/organic shape would be better.
Quote from: mitt on January 10, 2009, 10:38:38 AM
good facts.
seems to me that torsion is a more relevant factor for swingarms than bending, no?
CowboyBeebop
localhero365
Although I knew I wanted an S4R, this little gem of engineering was one of the reasons I really love this bike. I always draw admirers' attention to it, so much nicer than the usual swingarm.
Rameses
Quote from: ducatizzzz on January 10, 2009, 01:03:47 PM
good facts.
That's a good question.
For a sss, maybe.
But for a dss, I'd say no.  Since both ends of the axle are supported, there's little to no torsional force on each side of the swingarm.
Quote from: Rameses on January 11, 2009, 09:49:23 AM
For a sss, maybe.
i believe it is relevant -- even if you have a dss, the torsion is transferred to the frame. all bikes endure torsional forces when turning (leaning).
SKOM
My SSS got me out of a speeding ticket once.  ;)
"Die gefährlichste Weltanschauung ist die Weltanschauung derer, die die Welt nie angeschaut haben."
â€" Alexander Von Humboldt
peanut_man
Quote from: pompetta on January 10, 2009, 09:31:18 AM
I love this board.
I still didn't see any hot chic.  That's key!
2005 Buell XB12S | 2006 Honda CBR 600RR | 2005 Ducati Multistrada 1000DS | 2009 Ducati Monster 696+
Rameses
Quote from: ducatizzzz on January 11, 2009, 02:48:41 PM
True.
But that's not a torsional force on the components of the swingarm itself.
That's bending one arm up and one arm down.
Quote from: Rameses on January 11, 2009, 08:15:03 PM
True.
which would transfer to the swingarm pin in the engine case and torque the stressed engine case against the frame, no?
