R & G Tail Tidey
Started by Big Troubled Bear, January 12, 2009, 05:47:13 AM
Quote from: ducatitorrey on February 16, 2009, 05:27:30 AM
that's not too bad. what blinkers are those? i do like the cw in the rear position, between the exhaust hangers. I'm torn, but now i'm still thinking more towards the R&G. hmmmm
do either of thes replace or move the tool kit? what about helmet lock? (is there one?) bike should be delivered later this week, so  i've got time
getting a little ahead of myself!  [cheeky]
ok, the helmet holder hook is under the seat along with the tool kit. neither CW nor the R&G affect those.
the R&G definitely can't be moved up under the tail like that. but then again you can't use the stock turn signals at that position either. i think the LEDs you see on the pic below are his solution for turn signals.
w7ck7d
Yes those are my led turn signals..
09' 696 Black
94' BRONCO 5.8 EB
DucatiTorrey
Awesome, thanks for all your help fellas. Both solutions look like they are working out great for you both. I'll post back up here when i've got either one installed in the next week or so.
Thanks again!
  - real place
w7ck7d
If your getting the CW kit..Would look even better if you paint it black..
09' 696 Black
94' BRONCO 5.8 EB
DucatiTorrey
definitely! considering maybe some rubber edging also, but we'll see what i end up doing.
  - real place
Quote from: ducatitorrey on February 16, 2009, 05:54:05 AM
if you are sticking with the CW, those are good mods.
w7ck7d
the edging shouldnt be a big deal coz its well under..or if you want you can sand the edging down lil bit
09' 696 Black
94' BRONCO 5.8 EB
