January 24, 2025, 08:41:11 PM *
Pages: 1 [2]   Go Down
Author Topic: what style and size battery to put on a monster?  (Read 4033 times)
needtorque
« Reply #15 on: January 18, 2009, 08:18:01 AM »
$240 from me Smiley  Try loosing 9lbs with 240$ elsewhere? waytogo
According to the link it's 7 lbs weight loss.  8 lbs 12 oz. vs 1lb 7 oz.   Still great weight loss for the money though.
Who insures the FDIC?
sbrguy
« Reply #16 on: January 20, 2009, 09:10:05 AM »
looks like everyone says the yuasa battery is the way to go and has good experiences with them.
however the bike came stock with the GS battery which some people have said is a battery that had a lot of leaks guess i was lucky in that mine has not leaked but i'll change it before it does.  did GS eventually fix that problem as its a cheaper battery than the comparable Yuasa brand.  Funny thing is that they are affiliated companies.
moto
« Reply #17 on: January 20, 2009, 09:44:30 AM »
The Speedcell is a very nice battery if you are looking to drop weight on your bike. It does not need to be hooked up to a tender. It loses only 1% per month- so it can sit for 3-4 months and only lose 3 to 4% of its capacity. The small size makes it an easy install.
The latest batch of Speedcell batteries will have a maintenance lead that will allow you to balance the batteries. Everyting will be included so you can do this. This will extend the life of the batteries.
We will also have a batch made with Quick-Disconnects so you can easily pull the battery out, charge it or use on several bikes. We have several project bikes here- and they are never ridden all at once. Instead of installing expensive batteries on each bike, we are making Quick Disconnect leads for each bike. We'll just pop a battery in whichever bike we ride. This will end up saving us a lot of money in the long run.
We will be stocking the Speedcell batteries and handling warranties here.
The 240 amp SBK version retail for $250 but we offer them for a lot less right now if you register on our website for passwords.
SpeedCell SBK Battery
-M
www.motowheels.com
96 M944
98 900SS FE
01 996R
02 MV Agusta F4 750
05 999R
06 SC1000
07 1098
08 M696
sbrguy
« Reply #18 on: January 24, 2009, 09:00:27 AM »
got hte YUASA battery as suggested, filled charged and sealed up.
got a question on the battery there are what looks like two small vent covers or something near the battery terminals, are you suppoed to NOT touch these at all?  or do you have to open them before putting the battery on?
thanks.
« Reply #19 on: January 24, 2009, 02:19:34 PM »
thanks.
Do not touch them.  They are vents, but only open if the internal pressure is really high to prevent the battery from exploding.  If all is good the battery needs no venting, therefore the terminology "sealed battery".  Also fully charge the battery before putting it into service.
sbrguy
« Reply #20 on: January 24, 2009, 02:44:46 PM »
thanks for the heads up.  installed teh battery DID NOT touch the vents at all.  works perfectly in this 20degree F weather we are having in the dc area at night now.
damn that battery acid smells horrible, nobody told me that the sulfer/raw egg smell reeks so bad while you are filling it up.
looks like the old battery was not in as bad condition as i thought, basically tested it and it holds a charge pretty well, it only let me down on one really cold night -1F outside, then i remembered that it did give me about 4 long tries of startig it before conking out.
anyone need a NON leaking GS battery that still holds a charge that would proably be good for a warm weather person that rides often?  real cheap like 15$ or so and you pay shipping.
Capo
You Are What You Is
« Reply #21 on: January 24, 2009, 04:57:18 PM »
Iam  confused as to exactly what battery you have purchased.
Both of the Yuasa batteries that I have came plug and play out of the box. No vent or fill covers.
Could you post a pic?
Capo de tuti capi
sbrguy
« Reply #22 on: January 24, 2009, 05:06:57 PM »
I got the maintence free YUASA YT12B-BS battery, came from online dealer, with the acid packs in the box with the battery, you had to put the acid in, charge the battery and then it came with a what looked like a strip of bottle caps strng together that you put on the top fo th battery to give it a smooth appearance, drop it in the bike its done.
dont' know how to do the pics thing with this but i'll try tomorrow.
battery looked like this out of the box
http://www.batteriesxpress.com/Store/images/YT12B-BS.gif
« Last Edit: January 24, 2009, 05:08:35 PM by sbrguy » Logged
Capo
You Are What You Is
« Reply #23 on: January 24, 2009, 05:29:16 PM »
Yup that looks like mine.
Capo de tuti capi
« Reply #24 on: January 24, 2009, 08:52:23 PM »
I'm not sure about the rest of the world, but in the US that particular model is sold with the acid separate, which is a good thing since battery life starts the day you activate it.  A rack of measured tubes are used to fill the battery so you don't have to worry about over or under filling.  Strangely, most of the other Yuasa AGM batteries come with the acid already in.
Pages: 1 [2]   Go Up
