January 09, 2025, 08:11:36 PM *
Pages: 1 2 [3] 4   Go Down
Author Topic: New!! CarbonDry PROTEC Coating Service!!! Cmon modders, this will inspire you.  (Read 11261 times)
COWBOY
« Reply #30 on: January 22, 2009, 11:31:48 AM »
Value is measured in more terms than mere performance.
Look at OCC Choppers, or drive through the hood and look at the 1986 Cutlass worth 150$ with 6,000$ 28" rims, jacked up, and painted for some odd reason like a Sprite can, even though they aren't paid advertisements...
As for me personally, I do see value in the service, and I could see myself having items like a Frame, Subframe, Front fairing stay, Wheels, and Swingarm done in such a fashion (that is of course, when I could afford it, and it would not be my first priority, as I am not super well off).
Sure value can be a matter of perception.
Doesn't mean the rest of us don't laugh at the retard who spent 5K to put a diamond hour adjuster on his 3K Rolex.
I'm out before this continues to crash and burn.  I'm not trying to piss in your Cheerios but you're starting to hold the bowl for me.
2005 S2R -- Mods installed: DP termi full racing kit, ST4 Forks, S4R rear shock, 999 Radial Brake and Clutch MCs, 4 pot Brembo Calipers, 320mm Snowflake rotors, SBK Quick change carrier, 43T rear sproket, Tomaselli Clip Ons, Cyclecat Frame Sliders, ASV Levers, zero indicators, Supernova taillight
SP3
« Reply #31 on: January 22, 2009, 04:51:26 PM »
I don't see the point myself. To have a front wheel done is over $800 and you still have to add shipping to/from Japan (with insurance if you're smart). Call it $1000 for just having the front done. What do you have in the end? A stock wheel that is somewhat stronger but is now also heavier for a price that approaches a BST that is stonger and MUCH LIGHTER.
Maybe I am jaded from having made a living working on proper racecars in the past but the only reasons for using carbon composites was (IS!) much less weight for the same strength not for the "pretty" factor. This process is mainly for the pretty and not much at all for the strength:weight beneift.
If one is looking for the cool factor great, but is still seems way overpriced even then.
1991 851 SP3
1966 250 Monza
1999 Monster 900 City
« Reply #32 on: January 23, 2009, 05:12:41 AM »
seems all CarbonDry products are expensive.
What would be better is if they would bring down their costs and start producing pieces that are reegineered to be lighter and stronger. not just for visuals.
Rob Hilding
« Reply #33 on: January 23, 2009, 06:40:43 AM »
Makes me think of one of these:
http://www.turbonator.com/index.html?id=AdWordsTurbonator
« Last Edit: January 23, 2009, 10:51:52 AM by bozcoRob » Logged
Mojo S2R
. Dark Mojo .
« Reply #34 on: January 23, 2009, 10:04:44 AM »
Just add this to finish it off.
http://www.amazon.com/Exhaust-BOV-%C3%A2-Turbo-Sound/dp/B000IPV3MG
 laughingdp
BellissiMoto
« Reply #35 on: January 23, 2009, 12:12:47 PM »
Ummmmmmm Buddy,
Carbon Dry parts are all expensive BECAUSE their parts are lighter and stronger than any other Carbon on the market.
go here for more info - http://bellissimoto.com/CarbonTutorial.html
« Reply #36 on: January 23, 2009, 02:52:14 PM »
Ummmmmmm Buddy,
what i meant was, the pieces that are being coated with that process. they should offer already coated, lightened pieces instead of sending in stock pieces for adding on stuff.
but yes they are expensive. but that's the price we pay for hi-end stuff.
dbran1949
2007 S4RS Black Termis
« Reply #37 on: January 23, 2009, 03:11:46 PM »
This is an interesting idea. So a question for the OP
Could you mill some of the existing material off, say for instance a few thou off a wheel rim which would both lighten and weaken the rim. Then put the "carbon fiber coating" on the part which should bring the strength back up to, or maybe still better than the original?
Capo
You Are What You Is
« Reply #38 on: January 23, 2009, 03:35:49 PM »
Ummmmmmm Buddy,
But they are not carbon, just parts 'painted' with carbon.
Capo de tuti capi
Rob Hilding
« Reply #39 on: January 23, 2009, 03:43:46 PM »
But they will increase your fuel economy by 10% Wink
rgramjet
« Reply #40 on: January 23, 2009, 04:58:36 PM »
and make you go 140!
You're obviously a crack smokin' redneck carpenter. Kiss
-Sofadriver
For $50 you can touch my
« Reply #41 on: January 23, 2009, 05:07:23 PM »
I would avoid that with something structural like a wheel rim. There's no proper way of knowing what strength it is at after. Buy a carbon fiber wheel.
COWBOY
« Reply #42 on: January 23, 2009, 05:24:59 PM »
Ivan
Turn 3 at Streets of Willow
« Reply #43 on: January 23, 2009, 05:38:47 PM »
Two words.... "moto jewelry"     vomit
Sold: 2007 S2R1000 for canyon carving and commuting - DP ECU, PCIII, BMC air filter with open box, Zard full exhaust, Race-tech fork internals, Ohlins steering damper, and a Penske 8987 triple clicker
2000 996XU (extra ugly) for track days - BST carbon wheels, Ohlins shock, reworked fork, FBF exhaust, and a bunch of megacycle rocker arms. The rest of it is junk - Hey, I'm just happy that it runs...
Sold: 2002 Aprilia RST1000 for touring - De-restricted airbox, Taylormade Racing exhaust
Rob Hilding
« Reply #44 on: January 23, 2009, 05:43:39 PM »
laughingdp laughingdp laughingdp
Pages: 1 2 [3] 4   Go Up
