Worlds largest piston engine - 100,000hp @102rpm
Started by Oldfisti, January 22, 2009, 07:40:58 PM
Le Pirate
so....uh....how many gallons per mile?
can you tell i'm not an engineer?  [laugh]
Capo
#31
Quote from: alfisti on January 23, 2009, 11:29:16 AM
Yes. Of course. Heenan & Freud.
[laugh]  Seriously though, I'm not familiar and a quick search yielded nothing.  How does it work?
Its basically a water pump
What they don't know about dynamometers is not worth knowing.
http://www.froudehofmann.com/product_family_28.htm
http://cgi.ebay.co.uk/1963-Heenan-Froude-Worcester-Ship-Dynamometer-Advert_W0QQitemZ400023218583QQihZ027QQcategoryZ69515QQcmdZViewItem
Capo de tuti capi
Langanobob
QuoteThat's F'n nuts, are you sure about that 10,000 rpm?
Dang, I hate it when this happens.  I made that post at midnight-30 and should have thought it through more better.  It's been about 9 years and I did some remembering and it was closer to 8,000 RPM (still pretty fast  :)) and I'm not sure about the exact 6 foot rotor diameter.  It was a big sucker though.   If I can find some pictures I'll post them.  The rotor was aluminum, I think it was the compressor side that had the problems, and looking at the broken remnants you could see the internal area where the failure started, kind of like a star shaped crack.  I'm not a metallurgist but the failure analysis stuff is always interesting. I think the cause was bad forging or bad material.  Lots of politics and finger pointing and the manufacturer provided scatter shields like the ones on drag race clutches but there were no further problems.
Langanobob
QuoteNo problem maan.......just take a toke on this spliff and evrthing be ok
;D See you're an old Jamaica hand, either that or you live in NYC  :).  Try as I could, I never mastered Jamaican Patois, even though it's supposed to be based on Englsih.  Lots of fun trying.
Seriously, the Jamaicans I worked with were skilled, serious about their jobs and in general were a lot smarter and harder working than their US power plant operator counterparts.   Really enjoyed the Jamaican experience.
superjohn
OK. So what's so magical about 5252 ? Why is torque and HP the same at that rpm?
Quote from: superjohn on January 23, 2009, 04:01:38 PM
Can't tell you. Secret engineering mystery  ;D
superjohn
Quote from: MrIncredible on January 23, 2009, 04:09:02 PM
It's one of those Illuminati stone mason secrets isn't it?
Quote from: superjohn on January 23, 2009, 04:15:28 PM
More like, you don't want to get into that level of geekiness. Seriously-we're in our own little world, and it's not pleasant.
Capo
HP=TORQUE X RPM / 5252
James Watt determined one horsepower as 150 pounds, 220 feet in one minute.
Convert 150 pounds of force to foot pounds torque.
Assume the force of 150 pounds is "applied" tangentially to a one foot radius circle. This would be 150 foot pounds torque.
Convert  220 feet in one minute to RPM.
The circumference of a one foot(from the assumption above) radius circle is 6.283186 ft. (Pi D)
The distance of 220 feet, divided by 6.283185 feet, equals 35.014 RPM
Factors are one horsepower,150 pounds of force (torque), and 35 RPM.
Constant (X) = 150 ft.lbs. * 35.014 RPM / 1hp
35.014 * 150 / 1 = 5252.1
Therefore the constant is equal to 5252
So then hp = torque * RPM / 5252
Below 5252 rpm any engine's torque number will always be higher than its horsepower number
Above 5252 rpm any engine's horsepower number will always be higher than its torque number
At 5252 rpm the horsepower and torque numbers will be exactly the same.
Capo de tuti capi
Quote from: Capo on January 23, 2009, 04:30:06 PM
Most observers familiar with horses and their capabilities estimate that Watt was either a bit optimistic or intended to under promise and over deliver; few horses can maintain that effort for long.
Capo
#40
I prefer to use the watt as a unit of power measurement as it is based on physics (one joule of energy per second) rather than observations of a horse.
HP however produces the larger number and that is what people want to see
Capo de tuti capi
Quote from: Capo on January 23, 2009, 04:46:29 PM
Maybe I should start telling people the length of my junk in centimeters.  :P
superjohn
Quote from: MrIncredible on January 23, 2009, 05:00:37 PM
I do that. That's right ladies. 7.5..... Uh huh...... :'(
Thanks for the explanation Capo. That makes sense. I figured it had something to do with the definition of HP.
Speedbag
Backed up by any dyno sheet which will show that the HP and torque curves for any engine always intersect at 5252 RPM.  ;)
Oldfisti
Quote from: Speedbag on January 23, 2009, 06:12:12 PM
Now there's a man who knows his dyno sheets!  [thumbsup]   Much dyno experience?  I have a bit. Even though it's borderline bench racing I find it exiting finding HP on the dyno during tuning.   ;)
