February 06, 2025, 07:21:34 PM *
Pages: 1 [2] 3   Go Down
Author Topic: wet clutch to dry clutch slipper conversion  (Read 16089 times)
caperix
« Reply #15 on: February 01, 2009, 05:51:27 AM »
Small cased Ducati engines are only designed to get wet-clutches so therefore, converting it to a dry clutch is NOT the same as converting a large cased Ducati engine from a wet to a dry clutch.
Large cased engines (no order)
900
748/916/996
998
749/999
1098/848
DS1000/DS1100
Small cased engines (no order)
400
600
620
695
696 (?)
803
750
And a BIG +1 to the hassle comments on coversion and the 'not worth the $$$' comments as well.  But, even with that said and admitted...I'm still building another 750 with a dry-clutch for my Cafe-Racer.  (actually it'll be an 885cc motor)
Stew, sorry for keeping this issue alive.  Being the owner of 2 wet clutch Ducati's, although not planing on converting either of them, this has peaked my interest.  Could you please elaborate on wear the problem lies, as you have first hand experience with it.  Looking at the hot rod 750 it looks like the case off the wet clutch bike bolted on with out any visible modifications, is it that the transmission input shaft is a diff, size/length/spline count?
« Reply #16 on: February 01, 2009, 08:12:13 PM »
I didn't know there was a difference in cases.  What makes a case "large" vs. "small"?  Are they actually significantly smaller or larger dimmensionally?
Large case motors have deeper oil sumps and the transmission shafts are spaced differently so a big trans won't fit a small case.  The two mounting points are the same obviously.
« Reply #17 on: February 01, 2009, 08:13:56 PM »
The clutch side covers do swap and you will have to change the primary gear set with a dry-clutch one so externally...it looks like it just 'bolts on'.
It don't.  MANY differences between the transmission input shafts and the bearing spacers, and the.....well....lots of little things really.
caperix
« Reply #18 on: February 02, 2009, 03:38:08 PM »
Thanks for the reply, other threads have speculated about what the differnece is but this is the first time I have seen it in writing.
Feral 859
« Reply #19 on: February 02, 2009, 09:42:58 PM »
i was hoping there was something amazing that happened.  i would pay reasonably big bucks to have a dry clutch on my 800.  i was excited about being able to have the dry clutch when i bought the bike, but i didnt know.  oh the torture!!
Just do it to your bike.
« Last Edit: September 12, 2010, 06:10:39 PM by kopfjäger » Logged
« Reply #20 on: February 02, 2009, 10:20:17 PM »
Looks great!  waytogo
Better put an oil filter on that.  Grin
Feral 859
« Reply #21 on: February 02, 2009, 10:59:51 PM »
« Last Edit: September 12, 2010, 06:13:02 PM by kopfjäger » Logged
« Reply #22 on: September 11, 2010, 09:43:17 PM »
Reviving a thread.
Kopfjager. can you provide a parts list?
Stu, can you give me things to look for?
Feral 859
« Reply #23 on: September 12, 2010, 11:29:15 AM »
Reviving a thread.
Seriously bro, find a donor 1100 motor.
TAftonomos
is without a monster :(
« Reply #24 on: September 12, 2010, 12:10:37 PM »
Can I convert my dry clutch S4Rt into a wet clutch....just because? laughingdp
« Reply #25 on: September 12, 2010, 12:37:06 PM »
Yes.  It's easier than the other way around...
« Reply #26 on: September 12, 2010, 06:24:35 PM »
seriously?
is it because the 696 is the small case?
there have been small case stock dry clutches right?
« Last Edit: September 12, 2010, 06:28:25 PM by Raux » Logged
« Reply #27 on: September 13, 2010, 07:22:43 AM »
seriously?
The 696 is a small-case motor.
AFAIK, there haven't been any dry-clutch small-case motors in a production Ducati.
There's other folks here that know the history better, so YMMV.
duccarlos
« Reply #28 on: September 13, 2010, 07:35:19 AM »
Throwing gas into this fire... where does an S2R1000 fall into all this?
duccarlos
« Reply #29 on: September 13, 2010, 07:36:04 AM »
And in better terms, is it possible to swap that dry clutch from an 1000 to 800?
Pages: 1 [2] 3   Go Up
