January 10, 2025, 01:09:40 AM
help! need pn that is stamped on M696 oil cooler
Topic: help! need pn that is stamped on M696 oil cooler (Read 4286 times)
Re: help! need pn that is stamped on M696 oil cooler
Reply #30 on:
February 14, 2009, 03:52:34 PM »
yeah with the charcoal canister, i can see the routing you use will work. but with the euro shroud... it won't work so great. haveou thought about using a 90 degree on the outlet/inlet on the engine to clean up those angles?
hcomp
All this time I wondered what it was like to have a
Nothing to see here
Reply #31 on:
February 14, 2009, 04:10:37 PM »
With out getting too much into specifics, we have that part figured out. You need a special fitting to make that bend. We will only use AN aluminum fittings cause we like the look and how they work. The final production will be the special fittings.
Last Edit: February 14, 2009, 11:12:01 PM by ryanracer
にもかかわらず、私の車は本当に速いドライブ、私は女性の生殖器のようなバイクに乗る
Reply #32 on:
February 14, 2009, 04:15:08 PM »
if you can look up photos of the 1100 in their euro form i bet you can get a better idea of the tube runs with the small shroud.
hcomp
Nothing to see here
Reply #33 on:
February 14, 2009, 05:50:08 PM »
Found one Thanks Raux ! I also ordered the Euro shroud to make sure everything fits when finished. I am open to all suggestions, so keep the suggestions coming and thanks! I will make some new lines up next Monday and post some pics.
Regards,
Ryan
Last Edit: February 14, 2009, 11:13:20 PM by ryanracer
