Pics of my 696 dark
Started by monstermania, February 17, 2009, 05:41:57 PM
hcomp
WOW, that thing is BLACK!  Looks awesome! Like the forks a lot! I like the graphics too. If it is any consolation, I didn't think it said cockster.
にã,,かかã,ã,‰ãšã€ç§ã®è»Šã¯æœ¬å½"に速ã,,ドラã,¤ãƒ–、私は女性のç"Ÿæ®–器のã,ˆã†ãªãƒã,¤ã,¯ã«ä¹—ã,‹
myduc696
Are you planning on selling your OEM mirrors, if you still have it?
Thanks
monstermania
Quote from: DrNo08 on February 18, 2009, 08:57:21 PM
looks great.  Where did you get your vinyl fork wrap?
I ordered the vinyl fork wrap here   http://www.signsplusbanners.com/Oracal_851.html
Got this link from someone else off the forums who had done it before me.
Mine is the flat black.
w7ck7d
09' 696 Black
94' BRONCO 5.8 EB
monstermania
Quote from: w7ck7d on February 20, 2009, 12:44:48 AM
ist hard to wrap the fork??
The parts that I wrapped are easy, but I tried to do the lower beveled part at the bottom of the fork where it changes in size, and I could never get it to look good so I just took it off and left it. I have seen other peoples forks wrapped on here and they were able to do this part of the fork and it looked good but I can't figure out how they did it.
wisdesign
Just use a separate strip for the flared bit.  You'll never notice it's a separate piece... see?  BTW - Nice work!  [clap]
JTMOTO
I am going to try the vinyl wrap for my forks, after seeing yours I am inspired...I see on the website 15" 24" 30" 48" Oracal.  Which size did you buy?  What quantity? and was it the right amount?  Do you have any tips for me and does the vinyl overlap on the back side of the forks.  Sorry for the rapid firing of questions.  Bike looks great BTW [thumbsup]
Thanks
monstermania
Quote from: wisdesign on February 21, 2009, 07:32:32 AM
Yea, yours looks great! I couldn't get the small piece for the flare to stay on. It kept wanting to peel off.
monstermania
Quote from: JTMOTO on February 21, 2009, 12:07:52 PM
Thanks
I bought two pieces of the 24" and it was more than enough. The only tip I have is to do it where it is warm, you can also use a hairdryer to heat it up when you put it on, it seems to help it stick and handle better The pieces do slightly overlap on the inside of the fork but you can't tell.
monstermania
Hey guys, my bad, this is where I ordered my flat black vinyl.
http://www.vinyloutlet.net/631-ec15punched070black-1-2.aspx
Get the 10"x24",  two pieces,   It is only $2 a piece and it will be plenty to do the job.
wisdesign
Quote from: monstermania on February 21, 2009, 02:20:54 PM
Hunh.... weird.  Maybe try to clean it with alcohol and use some heat from a hairdryer or heat gun if you've got one.  Or... if it's not bothering you... just let it be.
Holden
I'd leave it. Nice little accent.
P.S. your heat shield is/was on backwards. ;)
monstermania
Quote from: wark on February 22, 2009, 09:59:00 AM
Thanks, I totally overlooked that.
DrNo08
Quote from: monstermania on February 21, 2009, 06:57:46 PM
Sweet!  Thanks
