Weeeeeeee Help me pick a new bike!!! (updated with pic!!)
Started by Labbedds, February 18, 2009, 09:32:37 AM
desmoquattro
Quote from: labbedds on February 20, 2009, 07:26:27 AM
This bike is starting to be a lot of fun.  It starts up so quickly and doesn't even need the choke like the s2r.  But DAMNN the clutch lever is so much stiffer to pull back.  I heard that best thing to do is change the clutch slave??  Any thoughts?  Thanks
I definitely recommend an aftermarket slave. If you get one, I can help you install it.
Also, forget coring the pipes. Get yourself an Arrow full system [thumbsup]
My Vices
'09 KTM 690 SMC (Thumpy)
'05 MS4R, blue
ROBsS4R
Quote from: desmoquattro on February 20, 2009, 07:51:15 PM
I was going to go with a after market slave since I split lanes often and a hour doing that your hand gets cramped.
However...
If you remove 2 springs you reduce the pull by 33% and its a free mod  [thumbsup]
desmoquattro
Quote from: ROBsS4R on February 20, 2009, 08:20:44 PM
However...
Not sure I'd want to do that...you might burn through clutch plates quicker.
My Vices
'05 MS4R, blue
ROBsS4R
Quote from: desmoquattro on February 20, 2009, 08:44:01 PM
So am I lucky with 26k on my clutch then  ;D
I am not sure how long plates are suppose to last but now since you said that I am sure I will have a problem... Dam you  >:(
desmoquattro
Quote from: ROBsS4R on February 20, 2009, 08:49:10 PM
Probably not, if you're just commuting. I, on the other hand, tend to burn them up ;D
My Vices
'05 MS4R, blue
