January 10, 2025, 01:08:34 AM *
Pages: 1 [2]   Go Down
Author Topic: Pipe alternatives  (Read 3896 times)
« Reply #15 on: March 01, 2009, 09:53:41 PM »
its not an alternative to a PC. the two of them have different effects in terms of your bike. DP is somewhere around $1200 factory, $600thru motowheels reflash tool (though it seems like once you buy it, you can only load 1 map onto that one particular ecu)
or around $500 thru monstermash, and he will even do it a second time with an updated map based a dyno sheet you provide him free. However i havent heard much of him doing this, so youll have to contact him directly.
that's only for the old style monsters though, the new monsters use Siemens ECUs and i'm pretty certain they can't be reflashed by this process yet
Also to clarify. the DP ECU comes with the Termi kits along with K&N filter. so for 1200 factory you are getting ALOT.
the PC adds on to your stock computer and modifies signals before and after the ECU. the DP ECU replaces your stock. there are other replacement ECUs but cost is much higher.
Clickjack
« Reply #16 on: March 02, 2009, 12:57:21 AM »
If you know were I can get the full Termi kit for 1200.00 please tell me.  That's the price I've found Arrows at but double that is as close as I've found Termi
"They wanted Gold, we gave them lead"  -John Wayne
Mojo S2R
. Dark Mojo .
« Reply #17 on: March 02, 2009, 01:07:42 AM »
Get the full kit without the midpipe.  Ducati sells two different "full-systems".  One with and one without the midpipe.  It's a difference of about $600 and then you can get the Marvings midpipe for about $360.  Besides I've read there are issues with the DP midpipe making it a PIA to change the Oil filter as it routes right over it and making some bellypan options out of the question.  I went with the full system without the midpipe for the price and am getting the Marvings midpipe shortly.
« Reply #18 on: March 02, 2009, 01:20:51 AM »
Also to clarify. the DP ECU comes with the Termi kits along with K&N filter. so for 1200 factory you are getting ALOT. [obviously not the FULL system price, but the slipons]
Pages: 1 [2]   Go Up
