Custom rear bearing spacer.
Started by TiAvenger, March 01, 2009, 06:11:42 PM
TiAvenger
I believe the hub itself has a lip that will be an issue, I wont really know until the brake arrives.
I guess I will have to wait till then.
I think I will order enough for 2 and have a machine shop make one, and make one myself for practice.
TiAvenger
The other issue (I've been thinking about) is future removal.  I would have to hit the spacer on one side to pop the bearing our on the other side. I dont know if it will be resilient  enough to stand more than one change out.  That or i would have to check the specs each time with a micrometer
SP3
Quote from: Speeddog on March 03, 2009, 10:19:57 AM
IMO, don't machine the hubs.
Make a stepped spacer, kinda like this:
                       _______________________
       _________|                                       |_____________
      |______________________________________________|
      _______________________________________________
      |_________                                        ______________|
                       |______________________|
Same ID as the 17mm spacer.
Major OD same as the OD of the 25mm spacer.
Length of the major OD portion same as the length of the 25mm spacer.
OD and length of the smaller ends to fit the ID and width of the 25mm bearings.
There's also the caliper bracket to consider, as well as the sprocket carrier....
This is a fairly involved deal, nearly impossible to get everything right via the internet....
Wanna give me a call?
Quote from: TiAvenger on March 03, 2009, 10:29:50 AM
So basically run 25mm bearings with the spacer carrying the axle through them?
The only component I don't have right now is the brake (caliper assembly/bracket)
Stu thinks the hub will have to be machined anyway to accept that. No way of knowing till I get it from Joels.
I was just pre planning so when the rest of the bike arrives, I can hit the ground running.
Red= axle  Blue = spacer Black = bearings Green= hub  note, not to scale.
That is what I did about 7 or 8 years ago. Mine is of 7075 T651. 6061 would suffice. Here is a pic of the finished item (from a thread on another forum).
http://www.ducati851and888.com/showpost.php?p=8555&postcount=8
1991 851 SP3
1966 250 Monza
1999 Monster 900 City
TiAvenger
Quote from: SP3 on March 03, 2009, 05:47:07 PM
No access to the picture.  :-[
How is bearing removal (if you have removed the bearings since.)
Desmo Demon
Quote from: TiAvenger on March 04, 2009, 06:49:39 AM
You need a stepped drift that will fit into the ID of the spacer and then a larger OD that will catch the spacer but still fit through the bearing's inner race. You will drive the spacer out with the bearing that is on the opposite side that you are using the drift.
Ducati used a stepped inner spacer on the front wheel of the Paso 750 to drop the ID from 20mm down to 17mm. I had a buddy of mine make a drift to drive the original bearings out. Ducati used a stepped spacer on the Paso 750's swingarm, also.
I don't have a picture of the front wheel's spacer, but here is a picture of the little one used in the Paso's swingarm.
This is a drawing I made for the Ducati Paso forum to show how the spacer is on the front wheel of the 750...
IBA #32735
SP3
No problem with removal. Press the spacer out of the wheel, the other bearing is still on the spacer, press the spacer out of second bearing.
1991 851 SP3
1966 250 Monza
TiAvenger
Thanks for the pictures. If you dont mind me asking, why did you not have it machined out of one piece?
With that, I think this one is pretty much *solved*
Though after using the search function it looks like the sprocket flange alignment may be a bigger issue.  :P
SP3
Quote from: TiAvenger on March 04, 2009, 01:49:37 PM
The spacer/sleeve pictured is one piece. Remember, it is for the front wheel.
1991 851 SP3
1966 250 Monza
TiAvenger
Quote from: SP3 on March 04, 2009, 03:04:01 PM
My bad. The reflection looks like a weld on the inside.
MrFryMoto
hmmm shouldn't be too hard to make
i would need to pick up some tools for the lathe (boring bits, tool holders, etc.) and i need to check out the head-play
MrFry's News Ticker:
TiAvenger
Quote from: MrFry - Cycles on March 05, 2009, 01:06:09 PM
What model do you have?  I think I still have my quick change tool holder on my ruined 300d
MrFryMoto
Quote from: TiAvenger on March 05, 2009, 01:10:52 PM
Craftsman 109.0702
