February 03, 2025, 03:07:01 AM
NorthWest
Suspension Thingy Kinda Place/People
Topic: Suspension Thingy Kinda Place/People (Read 9372 times)
Mother
Re: Suspension Thingy Kinda Place/People
Reply #15 on:
March 19, 2009, 06:45:15 AM »
its called an allen key, loosen 3 of them and it slides right off
NEIKOS
Reply #16 on:
March 19, 2009, 07:06:25 AM »
My shop manual indicates some special tool is required . . .
Allen key is all I need eh? Those tricky tricksters!
Mother
Reply #17 on:
March 19, 2009, 07:42:54 AM »
there is to remove the stearing stem bearing retainer/adjuster thingy but you can either make one or use channel locks on a putty knife, or use mine.
NEIKOS
Reply #18 on:
March 19, 2009, 02:47:47 PM »
I'm not touching your thingy thank you very much!
I think I can manage the channel lock/putty self made tool.
duc_fan
Reply #19 on:
March 19, 2009, 03:24:26 PM »
Crap, that reminds me... I need to check the steering head bearings on the SS. Some inspector who was feelin' up my bike as part of the ToR inspection thought they may be loose.
krolik
Yeah, that's me. So what.
Reply #20 on:
March 20, 2009, 08:57:20 PM »
Quote from: duc_fan on March 19, 2009, 03:24:26 PM
Feelin' up the SS? Is that a euphemism for somethin'?
Quote from: SacDuc
duc_fan
Reply #21 on:
March 20, 2009, 11:44:25 PM »
Quote from: krolik on March 20, 2009, 08:57:20 PM
Not really.
I remembered after I posted that, I think Amber was the one checking the bike that time. It just kinda looked like she was feelin' up my beautiful Supersport.
scott_araujo
Reply #22 on:
March 22, 2009, 05:45:45 PM »
Hey Chuck:
http://cgi.ebay.com/ebaymotors/2005-DUCATI-MONSTER-REAR-SHOCK-EXCELLENT-M620_W0QQitemZ290302749999QQcmdZViewItem
Scott
NEIKOS
Reply #23 on:
March 22, 2009, 05:48:34 PM »
Thanks.
I just SCORED an Ohlins DU 046 fully adjustable and rebuildable shock a few hours ago for an AMAZING frickin price! [moto]
Now I just gotta get it here, installed, and the steering bearing replaced and I'll be a happy man once again.
NEIKOS
Reply #24 on:
March 28, 2009, 09:02:06 AM »
Pretty sure this is gonna be too vague of a question but . . .
Would/will a steel rod the thickness of my pinky (3/8")hold up the front 1/2 of the bike while I remove the forks?
Also, is it possible to put the forks back on at the "wrong" length or different lengths and screw up the entire front end dynamics?
Tailgunner
Reply #25 on:
March 28, 2009, 10:25:36 AM »
Quote from: NEIKOS on March 28, 2009, 09:02:06 AM
I've used a 36" screwdriver pry bar through the foreward motor mount in the past. If you like the current position of your triple clamp/forks I would mark everything so you can return it to the same.
NEIKOS
Reply #26 on:
March 28, 2009, 11:19:19 AM »
What/where is this forward motor mount you speak of?
krolik
Reply #27 on:
March 28, 2009, 11:48:51 AM »
Quote from: NEIKOS on March 28, 2009, 11:19:19 AM
The big bolt on the side of the frame, where the frame sliders go.
Quote from: SacDuc
scott_araujo
Reply #28 on:
March 28, 2009, 04:37:51 PM »
Probably. I know a 2 x 4 across two jack stands works just fine, tried it the other day. Using re-bar?
And yes, absolutely. To get things right measure from the bottom of the LOWER triple clamp down to the end of the large outer fork tube. Set that back to where it was when you reassemble and you'll be where you were. Shorten a few mm (sliding forks up in the clamps) and it will turn in quicker but be less stable at speed.
Scott
Last Edit: March 28, 2009, 04:40:33 PM by scott_araujo
Visolara
Jacobs Love Meat
Reply #29 on:
March 29, 2009, 10:27:05 AM »
I have a spare front triple clamp stand (holds the bike from under the triple clamp) that you are welcome to using. This is what I use to pull/adjust my forks on all my bikes.
I actually have two different kinds, one is the pin kind, the other is a clasp type (used for the 749/999 series).
Maurice Miller
2009 OMRRA Rider Representative
OMRRA #39
WMRRA #39
Dark Horse Racing
Race Supporters -
Noel Communications, Inc. , 2Fast Motorcycle Track Days & Instruction , KBC Helmets , EDR Performance , Cascade Tracktime , GP Suspension North , KFG Dunlop LLC , LP Privateer , Dainese , AMS Oil
| 2006 Ducati 749S (street) | 2004 Suzuki SV650S (race) | 2002 Aprilia Mille (race) |
