February 23, 2025, 11:22:36 AM *
Pages: 1 [2]   Go Down
Author Topic: M1000 - Winter tinkering  (Read 3003 times)
Pedro
« Reply #15 on: March 19, 2009, 03:52:11 PM »
How did you put your spools (buttons, bobins not sure what you call them) on your swingarm?  Are they just drilled and tapped holes with shoulder screws?
Hi Mitt
the bobbins are R&G items - I drilled and tapped the swingarm and then added a nylock nut with threadlock as well for safety - I was a little concerned the threaded holes in the ally would pull through without the nut and I didn't want to come home to find it lying on its' side!
UKMOC President
www.ukmonster.co.uk
Currently bikes 1993 M900 (the original!) & 2004 1000DS Monsters!
Pedro
« Reply #16 on: March 19, 2009, 04:22:20 PM »
Just found the dyno chart from last year
Red line/numbers are at the crank
Blue line/numbers are at the front sprocket
Green line/numbers are at the rear wheel
As mentioned before, bike was running a little rich, cam timing needs doing and it now has a full Sil Moto/DP exhaust so it's off for more dyno work!
UKMOC President
www.ukmonster.co.uk
« Reply #17 on: March 20, 2009, 10:15:45 AM »
How did they determine numbers at the crank and the front sprocket? Do they have an engine dynamometer?
DuciD03
.... when did that happen...?
BTW: thats a bad pic of Bono, not me .... ;)
« Reply #18 on: March 20, 2009, 11:04:23 AM »
nice bit of work Pedro!  Heal gurads are a good idea having those pipe cans so close to your boots; might save the heals from melting ; )
some questions;
are those rizoma rearstes? (nice whateever they are)
Outside cases; how did you paint those, ie  Smoothrite what type of paint is that? powdercoated?
« Last Edit: March 20, 2009, 11:09:03 AM by DuciD03 » Logged
.... all the world is yours.
loves ze desmodromics.
« Reply #19 on: March 20, 2009, 11:08:39 AM »
Cycle Cat rearsets
Pedro
« Reply #20 on: March 20, 2009, 02:09:45 PM »
Not an expert on this but I believe the Fuchs Dyno used measures in both acceleration and deceleration and calculates the drag
UKMOC President
www.ukmonster.co.uk
Pedro
« Reply #21 on: March 20, 2009, 02:13:29 PM »
some questions;
Thanks.
Rear sets are as said above by Cycle Cat - don't think they make them anymore
Smoothrite is a smooth version of Hammerite that comes in a spray can. I just roughened the surface with a Scotchbrite pad, thoroughly degreased them, warmed them in the sun and applied 3-4 coats and let it cure off for about a week. All in all it cost me about 20 bucks!
UKMOC President
www.ukmonster.co.uk
Pages: 1 [2]   Go Up
