February 08, 2025, 12:54:17 PM *
Pages: 1 2 [3]   Go Down
Author Topic: Km's on a chain and other silly questions....  (Read 5398 times)
loony888
"I WAS GOING HOW FAST, OFFICER?"
« Reply #30 on: March 24, 2009, 01:51:35 AM »
i didn't mind maxima, as long as it's applied to a hot chain, as with all waxes it worked well. getting it out of the can however was not so good, i bought 3 cans and all of them i threw away with at least half the contents still inside, i now use TORCO and it's great.
paul.
                                              93 888 RS
                                              09 1098R BAYLISS
                                              07 Husqvarna TE 450
                                              01 S4         93 900M
                                              96 748SP
Spider
Ozmonsters: degenerating nicely since 2008
I may be long, but I fold up nicely
« Reply #31 on: March 24, 2009, 02:13:43 AM »
we must be using different products Bazz....I got no fling...but the amazing thing was on bikes and bicycles (mine was 2nd hand) application (like the Chris's CA cycleworks video) cleaned the chain and lubed....and the more often you use it the cleaner the drivetrain would get....I've turned noisy grundge encrusted Campagnolo (Italian bicycle components) drivetrains into jewel like silent efficient shifting mechanisms just by using it for a few weeks and lubing every 100k (which is normal for a bike) and 500k for the motor assisted vehicle.
I've used Belray stuff (suspension oil) and know how good that is too!
White Lion
« Reply #32 on: March 24, 2009, 02:14:37 PM »
Anyone know what size Rizoma brake/clutch cups to use? There are four to choose from: 20ml, 26ml, 27ml, 35ml. What the!??
Spider
« Reply #33 on: March 24, 2009, 04:00:27 PM »
I used the 27ml for the clutch and the 37 for the brake.
the brackets that are supplied go between the mirror stalk and the brake lever body.
the reservoirs come with different diameter output funnels (2.5mm allen key I think to screw them in...with a little grease I think)
If I had my time again...and I will!.....I'd do two of the 27 ml reservoirs with side ports.
and don't overfill them....you end up with brake fluid everywhere! and grease all the threads too.
White Lion
« Reply #34 on: March 24, 2009, 06:01:45 PM »
Thanks spider.
Why would you go the two 27ml instead of the larger 37?
*oh, can anyone else say if there is a problem by having a smaller brake reservoir?*
Spider
« Reply #35 on: March 24, 2009, 09:35:27 PM »
cause both of the sizes are a LOT less than the stock reservoirs if memory serves me....and after changing braking / clutch was same as always/before.
(it was the pads that changed the braking! WHOA!)
anyway.....I sent you an email.
Put reservoirs are great....I always thought the stock ones looked like urine containers....every time I rode I kept needing to go to the toilet  Smiley
bazz20
« Reply #36 on: March 25, 2009, 01:10:19 AM »
come on spider you were ment to bite ,ill have to go fishing  some where else old friend  waytogo
Spider
« Reply #37 on: March 25, 2009, 10:59:15 PM »
come on spider you were meant to bite ,ill have to go fishing  some where else old friend  waytogo
that wasn't fishing...you were just baiting the hook and I flew out of the water, took the bait and landed in the esky, in the boat, which you promptly shut with your foot.
bazz20
« Reply #38 on: March 26, 2009, 12:24:10 AM »
you can pay me back when you get a bike and do 2010 tourismo or are you waiting for 2020 model  laughingdp
Spider
« Reply #39 on: March 26, 2009, 02:43:02 AM »
I'm starting to think they didn't make too many of these S2r1000's....what they sold one or two in Australia?Huh?  Grin
limited edition!
Pages: 1 2 [3]   Go Up
