Epic brain farts.
Started by Popeye the Sailor, March 27, 2009, 12:04:02 PM
DucHead
Quote from: ducpainter on March 28, 2009, 03:42:40 PM
I'll get more space...
continue professor. ;D
Many of these are best when accompanied by a few cold ones...
Quote from: pompetta on April 01, 2009, 12:23:57 PM
I can appreciate that. :P
Jobu
Damn it, Dave.  You still haven't told us how to properly remove the rear brake caliper.   :-\   [laugh]
Rameses
Quote from: Ducaholic on March 31, 2009, 03:31:09 PM
Quote from: MrIncredible on March 31, 2009, 02:50:25 PM
He set it on fire, then put it out after it almost burned to the ground.
The lengths some people go to imitate me......so flattering.
fixed
Seriously, you wouldn't believe it.  The flames rolling off that thing were about 8 feet tall.
Quote from: Jobu on April 01, 2009, 08:33:48 PM
Yeah prof, I'm waiting for that one too.   ;D
Mother
there is a reason that sticker got created so long ago..."Turn the gas on dummy"
DucHead
#65
[laugh]
OK.
A few years ago I decided to remove my swingarm for powdercoating.  With several people in attendance to watch and assist, the very first thing I did was to remove the rear brake caliper -- by accidentally loosening the bolts that hold the halves of the caliper together!  :-\  Brake fluid leaked out and onto my wheel.  It was quickly cleaned up before any paint was damaged.  Luckily, the make the beast with two backs-up was not an omen, and the rest of the job proceeded smoothly -- although upon re-assembly it took me/us a while to figure out how to bleed the rear brake.   :D
My "friends" will never let me forget that one.   >:(   ;D  It was pretty funny though!  [laugh]
BTW, pretty much every tech session of mine begins with a similar scenario.   :P
Recently, I removed the radiator overflow bottle.  I had to remove the tank, airbox and pull up the throttle bodies.  I did all of that within 30 minutes, and reassembly was proceeding smoothly and even faster.  Until I dropped a fastener.  It took about 30 minutes to find it.   :-\  In the end, I spent nearly as much time looking for the fastener as I spent doing the actual job.  :P
Everyone needs a few 'friends'. ;)
DucHead
Quote from: ducpainter on April 02, 2009, 04:53:45 AM
True.
One brain fart that went unobserved by others occurred last year.  After changing the oil in the Bandit, I forgot to replace the oil fill plug.  I started the bike and rode about 1/2 mile whereupon I felt something "warm" on my right leg.  [laugh]
I looked down and...well you know the rest.  :P
hooligan machinist
QuoteI routinely tear the house apart looking for my glasses only to find them on my face.
I've done that as well. Only difference is that i had to ask my wife if she had seen my glasses. [bang]
cell # (931)-316-2020
Quote from: hooligan machinist on April 02, 2009, 07:18:51 PM
Been there, asked that...   [laugh]
Bun-bun
Not epic, but here's a life lesson I learned yesterday: If your gonna sandblast, don't wear a pocket t-shirt.
ROBsS4R
Quote from: MrFry - Cycles on March 27, 2009, 02:20:04 PM
After having my m620 for a while i was blasting down the freeway doing about 100mph 140MPH, i grab for more throttle and suddenly the bike dies.
i start thinking i seized the motor... but it seems to be rotating fine as i'm coasting to the side of the road
i check the oil level and drain plug... fine
i then think maybe i killed the electical system some how... but the headlight is still on - so it can't be too bad
i pull over and lift up the seat to check the fuses... everything looks OK
i check the plug wires... fine
try to start it... no go
check the fuses again... all looks ok
start dialing to call a friend and i notice the Kill switch is off
flip back on and the bike starts right up
i must have bumped it while twisting the throttle  [bang]
I have done that one before  ;D
OwnyTony
#72
Quote from: howie on March 27, 2009, 11:16:36 PM
Too many brain farts to remember and select as epic, but:
Most recent - left for the store to purchase a new printer, deal is a $50 rebate for turning in your old printer for recycling.  Forgot old printer :-[
Memorable - finished installing automatic transmission in BMW.  Looked down at floor to see torque converter sitting there [bang]
And you wondered why it went in/mated so easily the first time
recently,  installed radiator for lexus is300. put new fluid and waiting for thermostat to open and circulate (while cap was off). capped it back up, not thinking, car was drawing a vacume and hose was colaping .while car was warm, took the radiator cap instead of resivor cap (brain fart) to add fluid, sprayed half gallon of fluid everywhere . fortunately i didnt get sprayed
Speedbag
I welcome back this necro thread.  [thumbsup]
I didn't even remember starting this thread.
